need help predator stuck on back up screen
6.4hemiram
Post by 6.4hemiram »
ok here goes got a stage 3 sharadon trans loaded a new tune from david amalong in arizona any way worked great went to change the fueling in the pcm side seemed to be working fine then error on tcm load tool automatically tryed to load the original backup but keeps saying tcm error (-154) dont know what this means tryed uplugging and reconnecting goes right back to trying to load the backup and then this message please help
RE: need help predator stuck on back up screen
Was the tune locked? You can't change a locked tune.
Re: need help predator stuck on back up screen
6.4hemiram wrote:ok here goes got a stage 3 sharadon trans loaded a new tune from david amalong in arizona any way worked great went to change the fueling in the pcm side seemed to be working fine then error on tcm load tool automatically tryed to load the original backup but keeps saying tcm error (-154) dont know what this means tryed uplugging and reconnecting goes right back to trying to load the backup and then this message please help
will it restore the backup now?
6.4hemiram
RE: Re: need help predator stuck on back up screen
no wont do anything everytime i try to load it says the tcm code thing
6.4hemiram
Ok called tech support earlier today had me go thru tool enter some codes then I did the calid update on my computer went to load in truck PCM load no issues gets to tcm says failed error prepare vehicle (-154) what's up I can see everything with the data log and a separate scanner so I know it's not the truck
6.4hemiram
well called again went thru more steps now theres no tcm in the truck apparently according to predator and it wont load the original backup because its not there somehow waiting on a call back to see if the bench sim shows if its tool or pcm according to techs at diablo but truck is now totally undrivable wont even run starts and stalls
6.4hemiram
Still have not heard back yet I have a 40k lawn ornament right now that would look nice if it worked please help
what was the last thing you discussed with our techs?
if the truck will not start, and you bought the tool new, we'll pick up the PCM and get you fixed asap...
6.4hemiram
Last thing we talked about was someone at diablo was going to flash a PCM with my calid and see if they could get a predator to recognize it my predator says vehicle calid not supported or something along those lines and it does not pull up a calid for tcm in the options section but somehow the predator set the PCM side back to stock and then truck no start
I purchased the tool new from moes performance back in 2009 worked great up until a week ago have receipt if needed for proof of purchase
Really need truck to work getting rides to work is hard Thanks in advance
VA4MEDS
Post by VA4MEDS »
MikeL should be able to help you out Keith.
C'mon Mike he's one of the Good 'Ol FL boys
'10 5650 lb LeadSled Crew Cab: 13.401 @ 100.460 MPH
Custom Tunes by white lightning
Pushed & Chilled by Mr. Freeze
6.4hemiram
Yes us htc and Florida guys have to stick together hopefully we can get this going before fun day sunday on the 6th
ok, if it is not running we need to call tag it and get the pcm here for a reflash, as getting the truck going is the first problem.
give us a call and we'll issue a call tag.
JonDiablosport
Post by JonDiablosport »
where in fl are you located?
Diablosport Tech support
p: 561-908-0040
F: 561-908-0048
6.4hemiram
I'm in port st Lucie Florida
Received phone call will be filling out RMA for the tool and sending the tool and the PCM to you guys tomm hopefully we can get this going again
JonDiablosport
good deal the stuff will come to me and i will see what is taking place.
Too bad you were not a little closer.
Sorry for the delay Like i said on the phone something happened where there was not a follow up. that is not common. and we will get this situation resolved.
p: 561-908-0040
F: 561-908-0048
