2012 Camaro SS
greggash
2012 Camaro SS
Post by greggash »
Hello;
I am tuning my 2012 Camaro
after installing the Diablo Performance tune, it was much faster, but with a ping under WOT...and generally noisy
Predator part number U7194
Predator revision 9r29
2012 Camaro SS LS3 M6
So I data logged and used the "DSLogRedux" program.
It said that I needed to go Negative 3 on the injector slope.
I installed the tune, this time modifying the injector slope by negative 3.
The main thing I notice, is the engine generally sounds better, and I do not notice a ping.
Just did a data log, this time with the car totally warm.
my fuel trims
LTFT bank 1 is 1.56%
LTFT bank 2 is -0.781%
DsLogRedux suggests that I modify the injector slope -1 to compensate
My question, why do you tink the two banks are so far off from each other?
Thanks in advance
Gregg
RE: 2012 Camaro SS
Because the injectors aren't flow matched. They're flowing different amounts, so some cylinders get more gas then others.
RE: 2012 Camaro SS
thats not too far off at all, if both sides are within 2% of each other, no worries.
greggash
Post by greggash »
Today I will set the injector slope one more degree negative
That will be a total of 4 negative.
From what I have read, this basically tells it that the injectors are smaller, and to
Spray more fuel.
So I guess I was running a bit lean when I started.
P.S. I have a CAI also, no other mods
Thanks in advance
Gregg
Return to “General Questions”
