Power puck stack ?'s
Posted: Thu Mar 01, 2007 11:06 am
by UNDER-PRESSURE
Hi,
I first want to thank your company for a GREAT product. I've installed your Predator / Power puck stack in my 2003 Dodge Cummins & have a few ?'s.
I downloaded the Predator towing stack program & the truck runs great, far better than any other product i have tried. What setting should the puck be in for this program?
How do i make adjustments with the Predator & what changes can i make? I have 35" tires on the truck & would like to adjust for that & increase shift firmness if possible?
What should the puck be set at for the performance stack setting & is there any concerns with running the puck in the high hp / higher pressure setting?
Thank you for your time & any help!!
RE: Power puck stack ?
Posted: Thu Mar 01, 2007 4:26 pm
by johan
Well thank you. Unfortunately the Predator does not allow for tire size change, it is done in the abs module on those trucks, it does not allow for shift firmness adjustment either as it is in another module as well. Best bet would be to check out a good trans setup like ATS or Suncoast as the tranny is the weakest link in the dodge's drive train.
You can run the puck in any setting as long as you use the stacker tunes and the only thing i would be concerned about running high hp settings is your transmission.
