can't get predator to connect!
Posted: Mon Apr 23, 2012 8:07 pm
by setljohn
I'm running the U7134 on Windows 7. I've had my predator hooked up to my laptop before and it has worked fine. Now it is saying device cannot start or drivers not configured correctly. I have downloaded the driver that came with the cable and also the one you all offer under downloads. The cable is practically brand new and was purchased from Jeg's, identical to what you all sell. Any suggestions besides try a different cable?
RE: can
Posted: Tue Apr 24, 2012 10:37 am
here is the fix.
first off go to our website and download the windows vista driver.
install it.
reboot the computer and leave the usb to serial cable plugged in
go to start menu look for "my computer or computer"
right click it and go to properties.
then hardware - device manager.
Find the USb to serial cable most likely labeled" prolific usb to serial" or usb serial cable.
right click that and hit update drivers.
install from list or specific location. or browse my computer
dont search i will choose. or let me choose from a list.
scroll to ports if possible or click compatible hardware.
in the provided prolific cable drivers select the one labeled" prolific usb to serial comm port version 3.3.2.105
that should show up after you have installed the vista drivers and restarted your computer
This fix is for windows 7 64bit.
other versions of windows please click on this link www.diablosport.com/drivers then install it. once done installing remove the cable and reinsert. If it asks your to restart do so now and while restarting remove the cable from the computer.
when windows is fully booted up plug the cable back in and see if you get a successfull install message. if not try fix above.
RE: can
Posted: Tue Apr 24, 2012 11:29 am
by setljohn
It works! You the man.
