Idle RPM Settings
COLD_ZERO
Idle RPM Settings
Post by COLD_ZERO »
Maybe I'm doing something wrong- installed Performance CAI- then wanted to adjust the RPM settings in D, P, etc. Went to the Performance CAI option, clicked on Adjust, went to the RPM settings and they were all at the "0" (zero) mark with the ability to pump up 400 and down 400 from the 0 mark.
Q- What does the 0 represent, 750?
I'd like to know so that I can be sure the tune is taking each time.
CZ
__________________
2007 Ch SRT8 Brilliant Black Opt's I,II,III,Airaid CAI,MOPAR/cat back,BES Heads/Intake,Kooks long headers,Predator,180 T-Stat, one bad-ass driver.Best 0-60-4.28.
RE: Idle RPM Settings
The '0' represents wherever the idle is set to in the tune,and you can go up or down from there.
COLD_ZERO
Post by COLD_ZERO »
Is there a list that I can get into so I can know those values to see if the tune is taking?
Edit: **** Sorry Mike! Just saw your post about saving all for one post instead of many!!!
I'll keep them all together.
Thanks!
CZ
__________________
Idle is left stock in the tunes, so you are simply adding XXX rpms to the idle speed.
