U7185 and LLY Error.........
Posted: Tue May 08, 2012 5:41 pm
by danhercules
I try to "tune it" and when it wants to download the stock program I get an error message. :(
Its been a while since I have put a tune in my truck. I would say at least 12 months.
What should I do?
RE: U7185 and LLY Error.........
Posted: Tue May 08, 2012 6:06 pm
well, what is the error?
That would be the best place to start :)
older tool?
aftermarket electronics?
Posted: Tue May 08, 2012 7:15 pm
by danhercules
This is what the Predidor says...
"Vehical data backup
######ERROR#######
Reading process terminated
Press any key......"
Truck is all stock, exept K&N intake filter and intake tube.
Bought the programmer when the truck was just 6 month old. 04 Max with LLY.
Took tune out to get oil changed at dealer about 18 months ago and just now tried to put it back.
Posted: Wed May 09, 2012 11:17 am
something is causing an interruption...bad ground, low voltage?
Re: RE: U7185 and LLY Error.........
Posted: Wed May 09, 2012 7:18 pm
by danhercules
mikel wrote:something is causing an interruption...bad ground, low voltage?
Are you talking about the unit to the truck or are you talking about my truck, like the batteries and battery cable?
Truck operates fine, starts fine. My head unit for the stereo resets when there is low voltage. I replaced a battery about 4 weeks ago, stereo was resetting, but its been fine now.
Volt gauge on truck seems normal. Could it be my head unit powering up? It is a touch screen.
Posted: Thu May 10, 2012 10:13 am
ummm....
mikel wrote: aftermarket electronics?
The reason I asked, is because stereos are 99% the reason behind this issue on the older GM trucks ;)
Not so much the stereo, as the harness used to plug it into the stock harness, remove that, and try again.
Posted: Thu May 10, 2012 8:33 pm
by danhercules
ummm....
Are you talking about unplugging the stereo at the harness? What about just shutting down the stereo so its not pulling a load while trying turn on?
Thanks for your help.
RE: Re: RE: U7185 and LLY Error.........
Posted: Fri May 11, 2012 9:32 am
as mentioned, the harness is the issue, so it must be removed.
Re: RE: Re: RE: U7185 and LLY Error.........
Posted: Fri May 11, 2012 4:55 pm
by danhercules
mikel wrote:as mentioned, the harness is the issue, so it must be removed.
I was not sure what you meant by removing the harness. So I just unplugged the stereo harness and tried the tune. It worked. Then I plugged back in.
Thanks for your help. Sorry if I seemed a bit stupid.
Ill buy another Diablo tune in the future. Great customer service.
RE: Re: RE: Re: RE: U7185 and LLY Error.........
Posted: Fri May 11, 2012 5:07 pm
Glad we could help :)
Let that tranny relearn and enjoy!
Re: RE: Re: RE: Re: RE: U7185 and LLY Error.........
Posted: Fri May 11, 2012 7:18 pm
by danhercules
mikel wrote:Glad we could help :)
I am about 3/4 throttle now. Nice feeling that again. Its been 2 years. WHY DID I WAIT SOOOOO LONG???!?!?!?!!!! LOL
One more question, do you think I will have to unplug the harness when I take the tune out and put the stock one back in?
