Cruise control XXXX
Posted: Thu Oct 18, 2007 7:11 pm
by inrandy39
After turning off the ESP in the quik adjust menu I noticed that the antilock brakes are disabled, and also the cruise control will not work.
I think we should be able to disable all the traction control stuff while leaving the antilock brakes working along with the cruise control. I feel like the antilocks were disabled to help with power braking, but I want an option for everyday driving that lets the cruise control and the antilock brakes work. I can handle the power of my Charger but on wet roads if I have to avoid an obstacle I feel like the antilock brakes are a good thing.
Any thoughts?
Randy
RE: Cruise control XXXX
Posted: Fri Oct 19, 2007 10:38 am
You're only option there is to leave the ESP enabled, as otherwise everything else has to come off with it.
Re: RE: Cruise control XXXX
Posted: Fri Oct 19, 2007 5:50 pm
by inrandy39
mikel wrote:You're only option there is to leave the ESP enabled, as otherwise everything else has to come off with it.
I really wish you could change that, but thanks for the reponse anyway.
Randy
RE: Re: RE: Cruise control XXXX
Posted: Fri Oct 19, 2007 6:00 pm
by 1fastsedan
This is not a case of Diablo not working on it, but rather how the car is designed. The ABS and ESP are electronically intertwined systems and both use the ABS pump. You can't turn 1/2 the pump off.
Posted: Fri Oct 19, 2007 7:30 pm
by inrandy39
That makes sense, I have used the dash button and the "key to start while driving" trick and really can still feel the traction control kicking in. With your ESP off I did not feel any interactions besides my right foot which is the way it should be.
What about the cruise control?
Thanks very much for your inputs,
Randy
Posted: Fri Oct 19, 2007 9:13 pm
by AZOTH99
inrandy39 you could disable the ESP another way without the tuner. while driving 15mph min you turn the key for 3-5 seconds. it will fully disable ESP.
Re: RE: Re: RE: Cruise control XXXX
Posted: Fri Oct 19, 2007 9:52 pm
by inrandy39
AZOTH99 wrote:inrandy39 you could disable the ESP another way without the tuner. while driving 15mph min you turn the key for 3-5 seconds. it will fully disable ESP.
Are you saying that my "turn the key to start while driving slow" is the same mod as your no ESP without the antilock disable?
Again why is the cruse control disabled?
Randy
RE: Re: RE: Re: RE: Cruise control XXXX
Posted: Fri Oct 26, 2007 9:41 pm
by charginscott
The cruise control will turn off if the ESP kicks in. Matbe they are all intertwinded
Re: RE: Re: RE: Re: RE: Cruise control XXXX
Posted: Fri Oct 26, 2007 11:18 pm
by inrandy39
charginscott wrote:The cruise control will turn off if the ESP kicks in. Matbe they are all intertwinded
The last time I did the turn-key mod to see if it is the same as the Predator ESP off mod I could not control the tire spin with the gas pedal. I also noticed that even though I had turned the cruise control on before I left my driveway just to make sure that it would come on, after I was done playing on the wet roads the cruise control was not still turned on.
What I am asking for is to disable all the TSC and allow the antilock brakes to be still active. I still feel like the computer code controls both and could be adapted to allow both systems to work and only kill he cruise control when needed.
Randy
