2004 GMC 8.1 idles perfect won't go
Posted: Wed May 09, 2012 9:56 pm
2004 GMC 2500HD with 8100 Vortec Allison 5 speed
Predator U7193x
Updated to version v.9r11 May 4 , 2012
I first removed the 3 fuses as per the instructions . Installed the 87 tune with no mods to any parameters . Started truck and it had surgy idle . Tried driving the truck and it just falls on its face off idle . No codes , nothing . Won't rev fast in low gear , will sort of accellerate in 2nd but if you let off the gas won't go again . Reinstall stock tune runs normal . Had to go back
to work so wait a week to try again . First try at 87 tune removed 3 fuses again plus disconnect brake controller . Same as first time won't accelerate but no choppy idle . Also once it starts accelerating it keeps accelerating even when you let your foot off the gas . Reinstall stock tune back to normal
tried 87 tune again but correct for tire size and turn off torque management.
Same deal won't rev til 2nd then intermittent normal accel . In low gear will rev slow til redline shift .
Reinstall stock tune again and it's normal .
Saved the first tune with no mods and the original tune .
Is this a common problem with the 8.1 ?
If I can't load a tune what do I do with the Predator ?
Predator U7193x
