cts v 2007 LS2 not on the list
do i have to take another car or what i try cts v 2009 but not working good
RE: cts v 2007 LS2 not on the list
A 2009 will not work. Thats a supercharged motor, yours isn't. Its also a different computer.
I think an 07 Corvette should work, but not certain.
i send it to diablosport they fix it and i want to know the good car if i dont find mine i dont want to try another car and fuck that again please thanks
cts v 2007 kooks hd lt cat magnaflow k and n filter thanks
pick any 05+ Vette, or 08+ GM gas truck, etc.
ok i try vette 05 06 07 try tahoo with 6.0L try gto 06 nothing work when i compress i got no response from the motor i have to push the clutch and i can go again butevery time i leave the gaz pedal do the same thing im gona try to unplug my air mass sensor to try but id like to see my car in the list that gona be so easy ok thanks o i forget i try sierra 1500 too
your car's not going to run if you unplug the MAF sensor....
i install the diablo tunes and start the car and everything was good. my trinity show diablotune was installed and picked corvette 2005 like you had suggested. that didnt work so i tried 06,07,pick up gm 08 plus, gto 05,06,07 and it is still doing the same thing. acceleration is good but when i leave the gas to slow down on any gear
the motor not respond in any gear. i have to push the cluch or down shift and it seems ok intill i slow down again. it works fine its just when the car slows down. i have spent alot of time and money for this product and havent gotten a chance to use it. send some suggestions on this issue. i have recorded my original tunes and my diablo tunes on my trinity and dslogerux and i want to send that to you . could you send me the address to send this information. i have no trouble code on the car. your assistance is much needed. thanks
