does anyone know the stock fan settings on the 06 Charger SRT8?
I entered
180 for LS fan
205 for MS fan
220 for HS fan
I am on CAI perf 91 oct setting stock tstat
What should I enter for fan temp settings
Mike
06 Charger SRT8 Red loaded....Drive Moonshine5 Rims/Airaid CAI/Diablo Predator tune
copracer288
The fan settings are already adjusted for a 180 stat in the canned tune.
Turning on the LS fan at 180 might cause it to run too much.
When cruising on the highway I run between 183 - 185 with the 180 stat. The canned tune has the LS fan coming on at 190.
Rob
'07 Charger SRT8, black
Gone but not forgotten: '04 STi & '01 Camaro SS
Life Member: Veterans of Foreign Wars
Scottwoos06RT
If Diablo set fan for 180 stat at 190 low 199 high I would think you could set fans at 213 low 222 high as stock stat is 203degrees this would give you the same spread that they used. Stock settings are real high 219 low 226 high.christina wrote:If you would like to set it to stock settings, you can go into Modify Stock Tune and it will show you what it is at stock.
