PCM callibration for (VIN) is not supported???
GS81VETT
Post by GS81VETT »
First use on a 2005 Jeep Grand Cherokee 5.7 Hemi I did all of the updates and it says good to go and when I plug this in I get the error PCM Callibration for MY VIN is not supported?? What gives???
GS81VETT
RE: PCM callibration for (VIN) is not supported???
Post by GS81VETT »
Hey guys anyone on this? I have had this unit ONE day and can not use it. I need a responce please.
GS81VETT
Post by GS81VETT »
JonDiablosport
Post by JonDiablosport »
when it says pcm calibration not supported it means the car needs an update. You hit continue or check mark on that screen until it tells you to connect it to a pc based computer.
When you connect it to a computer it will download the required calibration update file. then when it is done you will take it back to your car choose tune vehicle- write vehicle and it will load and say a calibration has been loaded do you wish to update Hit the check mark.,
and follow prompts it will get you to update the vehicle prior to use.
Diablosport Tech support
p: 561-908-0040
F: 561-908-0048
GS81VETT
Post by GS81VETT »
Got ya! Thanks I will do that today!
GS81VETT
Post by GS81VETT »
Guys I have done what you told me and when I plut it into my PC the software starts and says it is up to date and when I take it to the car it starts all over?? What am I dong wrong?
bdog4u2
Post by bdog4u2 »
I'm having same problem on a 08 SRT8 Jeep I've had this thing for 1.5 weeks and haven't got to use it one time I could have put a super charger on quicker with less problems
Re: RE: PCM callibration for (VIN) is not supported???
bdog4u2 wrote:I'm having same problem on a 08 SRT8 Jeep I've had this thing for 1.5 weeks and haven't got to use it one time I could have put a super charger on quicker with less problems
have you sent us the info.xml file?
please do, or post it here.
NGreen
RE: Re: RE: PCM callibration for (VIN) is not supported???
Post by NGreen »
2008 Jeep Grand Cherokee 5.7 and I just finished updating the tool....I've got the same problem with the tool saying pcm calibration not supported for my VIN.
this is NOT a problem, its telling you that your vehicle needs an update, and it asks you to connect it to a PC with internet access to get the update from our server via the intune.exe
Crazyced
Post by Crazyced »
Plug it to a powered up PC with internet connection, fire up intune.exe and let it do it's thing for an hour (should be quicker but just to be safe).
You can also check the firmware info in the settings to make sure they are up to date.
Re: RE: Re: RE: PCM callibration for (VIN) is not supported?
Crazyced wrote:Plug it to a powered up PC with internet connection, fire up intune.exe and let it do it's thing for an hour (should be quicker but just to be safe).
assuming the tool is already updated, the cal update takes about 2 minutes start to finish :)
