traction control/stabilitrac override?
Posted: Wed Jun 13, 2012 1:55 pm
by bigboyblue
2010 silverado 6.2L
Im trying to find away to turn off all traction control but still cant.
Ive tried pressing the traction control button, but it still kicks in.
Ive tried holding the traction control button, even with stabilitrac disabled, it still kicks in.
Is the intune capable off deleting traction control and ABS completely, or do i need to run a bypass switch from the fuse to kill it.
RE: traction control/stabilitrac override?
Posted: Wed Jun 13, 2012 2:01 pm
ABS, no, TC can be disabled fully in a custom tune.
Posted: Wed Jun 13, 2012 2:14 pm
by bigboyblue
ok, so if i want to kill abs for off-road use, i gotta pull the fuse right?
Posted: Wed Jun 13, 2012 2:23 pm
I'd imagine thats the best option.
Posted: Mon Jun 18, 2012 4:35 pm
by mblatz
I-1000 intune, latest update
2008 dodge ram 1500, 4.7l motor
when i initially disable the traction control using the programmer (there is no actual switch) on my truck, if I do not key-off, just start the truck and drive, it seems to use [D] in third gear only and [2] and [1] in second gear even if i mash the pedal to the floor. any ideas? after key-off it works normally (with the ABS and BRAKE light on, of course)
Posted: Thu Jun 21, 2012 2:26 pm
by mblatz
Bump for mod
Posted: Thu Jun 21, 2012 2:44 pm
by Mike_Levy
Its throwing a code after the tune. You always need to key off and restart after a tune to cycle the computers power and clear it out.
Posted: Thu Jun 21, 2012 2:45 pm
can you post the info.xml file please/
this issue should be resolved with the latest 1r02a release.
