u1798 problem
socaldaddy
u1798 problem
Post by socaldaddy »
i m trying to hook on computer and i click on option and then i click on pc communication then all of sudden it sayXmodem time out i been struggle to get my data on pc... how do i do that? please let me know thanks
RE: u1798 problem
get what data on your PC? your 7198 predator does not save logs, so it can't be that.
are you trying to copy your original backup tune to your PC?? what program are you running when you get the xmodem timeout error?
socaldaddy
Re: RE: u1798 problem
06MonteSS wrote:get what data on your PC? your 7198 predator does not save logs, so it can't be that.
yep thats correct. i m using dataviewer 3.1 is there anything i can save data?
RE: Re: RE: u1798 problem
nope, not with the predator.
you can't save logs with yours, so the dataviewer isn't going to work for you... your predator is not supported by the dataviewer, so that's why you're getting the error.
socaldaddy
Re: RE: Re: RE: u1798 problem
06MonteSS wrote:nope, not with the predator.
ok then why do predator come with usb cable then? what is it for?
RE: Re: RE: Re: RE: u1798 problem
The cable allows you to upload tunes from your Predator to the PC or vice-versa.
socaldaddy
Re: RE: Re: RE: Re: RE: u1798 problem
mikel wrote:The cable allows you to upload tunes from your Predator to the PC or vice-versa.
how u do that because it keep say Xmodem Timeout.....
RE: Re: RE: Re: RE: Re: RE: u1798 problem
you're using the wrong app... you can't use the dataviewer...
the support download page for your predator is here:
http://diablosport.com/index.php?module ... lay&pid=17
instructions are on that page as well on how to use the correct app....
socaldaddy
Re: RE: Re: RE: Re: RE: Re: RE: u1798 problem
06MonteSS wrote:you're using the wrong app... you can't use the dataviewer...
instructions are on that page as well on how to use the correct appthanks man....
thanks man!
