Bouncing off rev limiter
Hello to all, I installed the Diablo last night and used the performance tune and changed my fan settings. when i took out last night and this morning, i was in, i think second or maybe thrid, it bounced off the rev limiter till i let off the gas, then it shifted. any ideas. also what should i set the fan settings at for low mph and high mph. i put them between 183 and 190 degrees.
RE: Bouncing off rev limiter
Did you disable autostick?
no i did not.... i was in D when this happened, i did think i had to. i am guessing i have disable the autostick. i love the tuner, it is great.
Sounds like maybe you installed the modify stock tune, rather than one of the performance tunes with the rev limiter raised?
then i will go back and install the performance tune
Re: RE: Bouncing off rev limiter
SRT Charger- Last night I reloaded the performance CAI tune following the download of the new update. Afterwards I tried to explore how to access some of the parameters listed. I enetered the Quick adjust menu where I was able to reset the transmission TCM and select raising the shift points. I did not have an option to set those points just a "yes" or "no" option. I selected "yes" and was wondering (1) what are the actual raised shift points settings via the modified performance CAI tune and (2) how can I access the modification window where the rev limiter is located? I just could not seem to map myself to this location. I must be doing something incorrectly. Thanks!mikel wrote:Sounds like maybe you installed the modify stock tune, rather than one of the performance tunes with the rev limiter raised?
OsuThunder
RE: Re: RE: Bouncing off rev limiter
umm look in the manual for the shift points its listed (i know 5.7 is 5800 and 6000), its a static raise, i think its 6200 for 1-2 and 2-3-4-5 is 6400. when you go to load up a tune, pick that tune, then pick modify tune, there is a rev limiter raise option. I kicked mine up 200 and no problems at all hitting it so far.
I do wonder, whats the stock rev limiter set at in a 5.7? just wondering if I can kick it down to x+100 rpm (right now its X + 200) and still be ok.
Verified shift points default to 6400rpm when selected. Thanks
