Transmission adaptation reset failed................WHY?
- fireman2118
I've been running a custom CMR tune in my 2005 Magnum for quite some time now. I updated my Intune and had no problems with making tune adjustments. The transmission reset adaptives was working fine.
Now, for some reason, when I hook up the Intune, the transmission adaptation reset fails. It will not work. Everything else seems to work fine.
I have an '05 Magnum with a standard TCM. The TCM was replaced in 2007
Calid 04896415AK
Calid 04896415AK
'05 Magnum R/T - 400 rwhp - 385 rwtq
PPP stage 3 heads, Howards cams 219/227 .600/.575 112 +4 , Ported 6.1 intake manifold, 85mm TB, JBA headers & mids, Corsa Sport, Dominator 3000 stall TC, stage II valve body, Getrag 3.91 LSD, BCR coilovers, Eibach sways, BWoody links, Wilwood big brake kit
RE: Transmission adaptation reset failed................WHY?
we're working on that.
- fireman2118
Any update on this?
- fireman2118
RE: The Riviera Resort Durgapur
F'n spammers!
Any update on the transmission adaptives reset issue?
- fireman2118
Is there any progress with the transmission adaptives reset "failed" issue?
It's been 3 weeks!
It's been 3 weeks!
- fireman2118
Update?............Please!
Re: RE: The Riviera Resort Durgapur
try this update please.fireman2118 wrote:Update?............Please!
- fireman2118
RE: Re: RE: The Riviera Resort Durgapur
1t02ca loaded and everything works as it should.
Outstanding work! Back in business, thanks.
Would this update apply in my case? I have an Intune running the latest update for my '06 Charger SRT8, and I get the Reset TCM Adaptation failed message.mikel wrote:try this update please.fireman2118 wrote:Update?............Please!
Thanks,
Josh
TheNeonFreak
any updates about RESET TCM ADAPTATION FAILED. I drive a 2015 dodge Charger SXT. I wasn’t able to install the ZF8 trans tune from Hemifever for some reason. Then I notice I can’t even reset the TCM adaptation. My i3 Tuner is up-to-date as of right now. Please and thank you. Also, for additional context, the Hemifever trans tune “installed” but when I was driving for like maybe a minute or two. The car started rolling and I couldn’t push forward. Stick was on D, but it felt like I was on neutral. I had to disconnect battery (engine was still running), so I disconnected the fuse to turn off the engine, put everything back, then installed the perf trans tune from Diablosport. Everything went back to normal after that. Been using the perf trans tune for 2 years now and it’s been running good. But I just wanted better transmission tuning. I did talked to Sean from Hemifever and he gave me another version of the time, but still same thing was happening. He’s not even sure why there’s some sort of disconnection with the TCM. Not sure if there’s something I’m missing here.mikel wrote: Mon Jul 16, 2012 11:17 amtry this update please.fireman2118 wrote:Update?............Please!
Check engine code: P1DF3
Re: Transmission adaptation reset failed................WHY?
please report the tcm adaption fail to our support team so they can get it documented and fixed.
As for the code with the custom tune, that is not something I have seen or heard of before, hard to say what may be causing it.
