using dataviewer on 2 cars question??
Posted: Sat Oct 27, 2007 11:49 am
by rage300c
hey guys i bought the tuner and have the dataviewer on my car.
i wanna data view on my friend jeep srt8 also, do i have to load my tunes in his car to view the data or can i just plug the predator into his just to use it for dataviewing...??? and leave the tune in my car???
also how accurate is the afr on the dataviewer?? or do we need to use a aftermarket wideband???
thanks frank,,
RE: using dataviewer on 2 cars question??
Posted: Sun Oct 28, 2007 9:44 am
by johnc
You can use the dataviewer on your friend's car, no problem. The AFR reading is only as accurate as the sensor on your car, which means not very. Whether you need a wideband or not depends on how serious you are about getting every last bit of horsepower out of your engine.
Posted: Sun Oct 28, 2007 10:56 pm
by rage300c
ok thanks will look into getting a wideband which do you recommend???
Posted: Mon Oct 29, 2007 8:30 am
by johnc
The pen of The World Famous Johan Mangs wrote:I personally use a Innovate, it is good as it allows you to recalibrate it. So is the AFX from NGK.
