Fan always on U7135
terremoto09
Fan always on U7135
Post by terremoto09 »
I install the new revision 8t16a.crom, to my diablosport, and still the fan turn on always, I got a Charger R/T, I would like to know the fan setting:
L =
M=
H=
Neubium
RE Fans on all the time
Post by Neubium »
The Predator tune is designed with a 180 degree thermostat in mind. If you replace the stock thermostat with a NAPA THM 165, Motorad 4128, or Jet Performance 10183, the fans will match up perfectly. If you choose to maintain the stock temperature thermostat the fan temp should be modified. There are numerous posts associated with fan temp settings utilizing stock thermostat. I do not know the right settings for best performance with the stock thermostat.
christina
RE: RE Fans on all the time
Post by christina »
To get the correct stock settings for your vehicle, you can go into Modify Stock Tune and look at the settings for the fan temps.
Christy High
lurker.
BUZ-CCC
Re: RE: RE Fans on all the time
Post by BUZ-CCC »
christina wrote:To get the correct stock settings for your vehicle, you can go into Modify Stock Tune and look at the settings for the fan temps.
If Diablo set fan for 180 stat at 190 low 199 high I would think you could set fans at 213 low 222 high as stock stat is 203degrees this would give you the same spread that they used. Stock settings are real high 219 low 226 high.
crazylikeacharger
Post by crazylikeacharger »
i just checked my stock tune on my car is it is as follows
Fans off
High MPH HS ON - 226.39
High MPH LS ON - 217.39
High MPH MS ON - 226.39
Low MPH HS ON - 226.39
Low MPH LS ON - 217.39
Low MPH MS ON - 226.39
ON
HS - 226.39
LS - 217.39
MS - 226.39
hope this helps anyone with a stock thermo
terremoto09
Works perfect with my R/T, if anybody have differents fan settings, post
