Need help, lean problem
Posted: Sun Oct 28, 2007 7:31 pm
I need some help that I cannot take care of with my U7191 for my 06 monte carlo ss 5.3v8.
From 4000-4900 rpms the car goes lean and then the a/f curve flattens out to where I want it. The problem is I cannot target just the 4000-4900 rpm range with the Diablo tuner, only 4000-7000 range overall. 4900 up to 6000 it is flat at 12.39 where I want it. Is there any thing that can be done to fix this, please see attached log.
Time Spark Advance Long Term Fuel Trim Bank 1 Engine Speed Commanded Throttle Position Equivalence Ratio Total Knock Spark Retard
Units deg % rpm % AFR deg
0:14:55:879 29.5 -0.7813 3511.5 100 13.93 0
0:14:56:029 29.5 -0.7813 3511.5 100 11.94 0
0:14:56:041 29.5 -0.7813 3511.5 100 11.94 0
0:14:56:054 29.5 -0.7813 3765 100 11.94 0
0:14:56:081 29.5 -0.7813 3765 100 11.94 0
0:14:56:108 29 -0.7813 3765 100 11.94 0
0:14:56:302 29 -0.7813 3765 100 11.94 0
0:14:56:372 29 -0.7813 3765 100 11.94 0
0:14:56:388 29 -0.7813 3765 100 11.94 0
0:14:56:413 29 -0.7813 3842.3 100 11.94 0
0:14:56:441 29 -0.7813 3842.3 100 11.94 0
0:14:56:552 28.5 -0.7813 3842.3 100 11.94 0
0:14:56:577 28.5 -0.7813 3842.3 100 11.94 0
0:14:56:707 28.5 -0.7813 3842.3 100 12.1 0
0:14:56:719 28.5 -0.7813 3842.3 100 12.1 0
0:14:56:747 28.5 -0.7813 3922.8 100 12.1 0
0:14:56:771 28.5 -0.7813 3922.8 100 12.1 0
0:14:56:891 28.5 -0.7813 3922.8 100 12.1 0
0:14:56:910 28.5 -0.7813 3922.8 100 12.1 0
0:14:56:937 28.5 -0.7813 3922.8 100 12.32 0
0:14:56:949 28.5 -0.7813 3922.8 100 12.32 0
0:14:56:964 28.5 -0.7813 3972.5 100 12.32 0
0:14:57:070 28.5 -0.7813 3972.5 100 12.32 0
0:14:57:092 28.5 -0.7813 3972.5 100 12.32 0
0:14:57:105 28.5 -0.7813 3972.5 100 12.32 0
0:14:57:141 28.5 -0.7813 3972.5 100 12.43 0
0:14:57:159 28.5 -0.7813 3972.5 100 12.43 0
0:14:57:183 28.5 -0.7813 4024 100 12.43 0
0:14:57:207 28.5 -0.7813 4024 100 12.43 0
0:14:57:323 28 -0.7813 4024 100 12.43 0
0:14:57:336 28 -0.7813 4024 100 12.43 0
0:14:57:476 28 -0.7813 4024 100 12.68 0
0:14:57:488 28 -0.7813 4024 100 12.68 0
0:14:57:501 28 -0.7813 4076.3 100 12.68 0
0:14:57:608 28 -0.7813 4076.3 100 12.68 0
0:14:57:630 28.5 -0.7813 4076.3 100 12.68 0
0:14:57:642 28.5 -0.7813 4076.3 100 12.68 0
0:14:57:771 28.5 -0.7813 4076.3 100 12.81 0
0:14:57:797 28.5 -0.7813 4076.3 100 12.81 0
0:14:57:823 28.5 -0.7813 4148.5 100 12.81 0
0:14:57:846 28.5 -0.7813 4148.5 100 12.81 0
0:14:57:959 29 -0.7813 4148.5 100 12.81 0
0:14:57:976 29 -0.7813 4148.5 100 12.81 0
0:14:58:100 29 -0.7813 4148.5 100 12.79 0
0:14:58:112 29 -0.7813 4148.5 100 12.79 0
0:14:58:131 29 -0.7813 4204 100 12.79 0
0:14:58:157 29 -0.7813 4204 100 12.79 0
0:14:58:184 29 -0.7813 4204 100 12.79 0
0:14:58:289 29 -0.7813 4204 100 12.79 0
0:14:58:359 29 -0.7813 4204 100 12.76 0
0:14:58:371 29 -0.7813 4204 100 12.76 0
0:14:58:385 29 -0.7813 4261.8 100 12.76 0
0:14:58:499 29 -0.7813 4261.8 100 12.76 0
0:14:58:512 29 -0.7813 4261.8 100 12.76 0
0:14:58:541 29 -0.7813 4261.8 100 12.76 0
0:14:58:617 29 -0.7813 4261.8 100 12.74 0
0:14:58:628 29 -0.7813 4261.8 100 12.74 0
0:14:58:641 29 -0.7813 4280.8 100 12.74 0
0:14:58:669 29 -0.7813 4280.8 100 12.74 0
0:14:58:691 29 -0.7813 4280.8 100 12.74 0
0:14:58:804 29 -0.7813 4280.8 100 12.74 0
0:14:58:859 29 -0.7813 4280.8 100 12.72 0
0:14:58:871 29 -0.7813 4280.8 100 12.72 0
0:14:58:899 29 -0.7813 4340.8 100 12.72 0
0:14:58:924 29 -0.7813 4340.8 100 12.72 0
0:14:58:947 29 -0.7813 4340.8 100 12.72 0
0:14:59:063 29 -0.7813 4340.8 100 12.72 0
0:14:59:114 29 -0.7813 4340.8 100 12.7 0
0:14:59:127 29 -0.7813 4340.8 100 12.7 0
0:14:59:155 29 -0.7813 4381 100 12.7 0
0:14:59:179 29 -0.7813 4381 100 12.7 0
0:14:59:297 29 -0.7813 4381 100 12.7 0
0:14:59:319 29 -0.7813 4381 100 12.7 0
0:14:59:368 29 -0.7813 4381 100 12.69 0
0:14:59:381 29 -0.7813 4381 100 12.69 0
0:14:59:394 29 -0.7813 4422.5 100 12.69 0
0:14:59:420 29 -0.7813 4422.5 100 12.69 0
0:14:59:434 29 -0.7813 4422.5 100 12.69 0
0:14:59:550 29 -0.7813 4422.5 100 12.69 0
0:14:59:626 29 -0.7813 4422.5 100 12.66 0
0:14:59:638 29 -0.7813 4422.5 100 12.66 0
0:15:00:199 29 -0.7813 4464.3 100 12.66 0
0:15:00:229 29 -0.7813 4464.3 100 12.66 0
0:15:00:346 29 -0.7813 4464.3 100 12.66 0
0:15:00:367 29 -0.7813 4464.3 100 12.66 0
0:15:00:421 29 -0.7813 4464.3 100 12.58 0
0:15:00:433 29 -0.7813 4464.3 100 12.58 0
0:15:00:457 29 -0.7813 4596 100 12.58 0
0:15:00:486 29 -0.7813 4596 100 12.58 0
0:15:00:598 29 -0.7813 4596 100 12.58 0
0:15:00:615 29 -0.7813 4596 100 12.58 0.1758
0:15:00:663 29 -0.7813 4596 100 12.53 0.1758
0:15:00:674 29 -0.7813 4596 100 12.53 0.1758
0:15:00:692 29 -0.7813 4664.3 100 12.53 0.1758
0:15:00:797 29 -0.7813 4664.3 100 12.53 0.1758
0:15:00:816 29 -0.7813 4664.3 100 12.53 0.1758
0:15:00:843 29 -0.7813 4664.3 100 12.53 0
0:15:00:868 29 -0.7813 4664.3 100 12.49 0
0:15:00:880 29 -0.7813 4664.3 100 12.49 0
0:15:00:893 29 -0.7813 4735.5 100 12.49 0
0:15:00:919 29 -0.7813 4735.5 100 12.49 0
0:15:00:946 29 -0.7813 4735.5 100 12.49 0
0:15:01:050 29 -0.7813 4735.5 100 12.49 0
0:15:01:099 29 -0.7813 4735.5 100 12.46 0
0:15:01:111 29 -0.7813 4735.5 100 12.46 0
0:15:01:126 29 -0.7813 4783.5 100 12.46 0
0:15:01:235 29 -0.7813 4783.5 100 12.46 0
0:15:01:252 29 -0.7813 4783.5 100 12.46 0
0:15:01:279 29 -0.7813 4783.5 100 12.46 0
0:15:01:306 29 -0.7813 4783.5 100 12.43 0
0:15:01:333 29 -0.7813 4783.5 100 12.43 0
0:15:01:356 29 -0.7813 4857.5 100 12.43 0
0:15:01:380 29 -0.7813 4857.5 100 12.43 0
0:15:01:487 29 -0.7813 4857.5 100 12.43 0
0:15:01:509 29 -0.7813 4857.5 100 12.43 0
0:15:01:562 29 -0.7813 4857.5 100 12.39 0
0:15:01:584 29 -0.7813 4857.5 100 12.39 0
0:15:01:613 29 -0.7813 4934.8 100 12.39 0
0:15:01:637 29 -0.7813 4934.8 100 12.39 0
0:15:01:740 29 -0.7813 4934.8 100 12.39 0
0:15:01:767 29 -0.7813 4934.8 100 12.39 0
0:15:01:801 29 -0.7813 4934.8 100 12.39 0
0:15:01:818 29 -0.7813 4934.8 100 12.39 0
0:15:01:841 29 -0.7813 4960.3 100 12.39 0
0:15:01:869 29 -0.7813 4960.3 100 12.39 0
0:15:01:891 29 -0.7813 4960.3 100 12.39 0
0:15:02:008 29 -0.7813 4960.3 100 12.39 0
0:15:02:055 29 -0.7813 4960.3 100 12.39 0
0:15:02:072 29 -0.7813 4960.3 100 12.39 0
0:15:02:097 29 -0.7813 5041 100 12.39 0
0:15:02:123 29 -0.7813 5041 100 12.39 0
0:15:02:243 29.5 -0.7813 5041 100 12.39 0
0:15:02:266 29.5 -0.7813 5041 100 12.39 0
0:15:02:407 29.5 -0.7813 5041 100 12.39 0
0:15:02:430 29.5 -0.7813 5041 100 12.39 0
0:15:02:458 29.5 -0.7813 5151.8 100 12.39 0
0:15:02:481 29.5 -0.7813 5151.8 100 12.39 0
0:15:02:586 29.5 -0.7813 5151.8 100 12.39 0
0:15:02:608 29.5 -0.7813 5151.8 100 12.39 0
0:15:02:647 29.5 -0.7813 5151.8 100 12.39 0
0:15:02:659 29.5 -0.7813 5151.8 100 12.39 0
0:15:02:687 29.5 -0.7813 5208.5 100 12.39 0
0:15:02:712 29.5 -0.7813 5208.5 100 12.39 0
0:15:02:739 29.5 -0.7813 5208.5 100 12.39 0
0:15:02:868 29.5 -0.7813 5208.5 100 12.39 0
0:15:02:904 29.5 -0.7813 5208.5 100 12.39 0
0:15:02:916 29.5 -0.7813 5208.5 100 12.39 0
0:15:02:929 29.5 -0.7813 5267.3 100 12.39 0
0:15:03:037 29.5 -0.7813 5267.3 100 12.39 0
0:15:03:056 29.5 -0.7813 5267.3 100 12.39 0
0:15:03:073 29.5 -0.7813 5267.3 100 12.39 0
0:15:03:108 29.5 -0.7813 5267.3 100 12.39 0
0:15:03:120 29.5 -0.7813 5267.3 100 12.39 0
0:15:03:149 29.5 -0.7813 5326.8 100 12.39 0
0:15:03:266 29.5 -0.7813 5326.8 100 12.39 0
0:15:03:288 30 -0.7813 5326.8 100 12.39 0
0:15:03:304 30 -0.7813 5326.8 100 12.39 0
0:15:03:429 30 -0.7813 5326.8 100 12.39 0
0:15:03:441 30 -0.7813 5326.8 100 12.39 0
0:15:03:455 30 -0.7813 5388.5 100 12.39 0
0:15:03:482 30 -0.7813 5388.5 100 12.39 0
0:15:03:506 30 -0.7813 5388.5 100 12.39 0
0:15:03:623 30 -0.7813 5388.5 100 12.39 0
0:15:03:671 30 -0.7813 5388.5 100 12.39 0
0:15:03:688 30 -0.7813 5388.5 100 12.39 0
0:15:03:712 30 -0.7813 5482.8 100 12.39 0
0:15:03:736 30 -0.7813 5482.8 100 12.39 0
0:15:03:857 31.5 -0.7813 5482.8 100 12.39 0
0:15:03:876 31.5 -0.7813 5482.8 100 12.39 0
0:15:04:004 31.5 -0.7813 5482.8 100 12.39 0
0:15:04:021 31.5 -0.7813 5482.8 100 12.39 0
0:15:04:044 31.5 -0.7813 5548 100 12.39 0
0:15:04:070 31.5 -0.7813 5548 100 12.39 0
0:15:04:097 31.5 -0.7813 5548 100 12.39 0
0:15:04:224 31.5 -0.7813 5548 100 12.39 0
0:15:04:273 31.5 -0.7813 5548 100 12.39 0
0:15:04:286 31.5 -0.7813 5548 100 12.39 0
0:15:04:299 31.5 -0.7813 5614 100 12.39 0
0:15:04:325 31.5 -0.7813 5614 100 12.39 0
0:15:04:352 31 -0.7813 5614 100 12.39 0
0:15:04:481 31 -0.7813 5614 100 12.39 0
0:15:04:606 31 -0.7813 5614 100 12.39 0
0:15:04:617 31 -0.7813 5614 100 12.39 0
0:15:04:635 31 -0.7813 5682.5 100 12.39 0
0:15:04:660 31 -0.7813 5682.5 100 12.39 0
0:15:04:683 32 -0.7813 5682.5 100 12.39 0
0:15:04:880 32 -0.7813 5682.5 100 12.39 0
0:15:04:942 32 -0.7813 5682.5 100 12.39 0
0:15:04:964 32 -0.7813 5682.5 100 12.39 0
0:15:04:978 32 -0.7813 5751.5 100 12.39 0
0:15:05:003 32 -0.7813 5751.5 100 12.39 0
0:15:05:016 31.5 -0.7813 5751.5 100 12.39 0
0:15:05:216 31.5 -0.7813 5751.5 100 12.39 0
0:15:05:276 31.5 -0.7813 5751.5 100 12.39 0
0:15:05:283 31.5 -0.7813 5751.5 100 12.39 0
0:15:05:302 31.5 -0.7813 5860.3 100 12.39 0
0:15:05:323 31.5 -0.7813 5860.3 100 12.39 0
0:15:05:335 32.5 -0.7813 5860.3 100 12.39 0
0:15:05:352 32.5 -0.7813 5860.3 100 12.39 0
0:15:05:553 32.5 -0.7813 5860.3 100 12.39 0
