unhappy with new update
2011 f150 5.0l,updated t1000 to v.1r09,noticed doesn't like to down shift at wot and part throttle upshifts are very fast and low rpms(1-4 in 50')also at highway cruise runs rich,i was happy with the previous update but the tuner won't let me program back to 1t08k,it says i require a password from you.
objects in mirror are losing
RE: unhappy with new update
can you please export the stock tune and the last tune written and post them here?
when i plugged into my pc the t1000 showed updatingcrom to 1r09a,and when i go to get tune files from tuner it says there is none,ps i returned my truck to stock so i could drive it.
if you restored, there are no files to export...
stock and 87 perf tunes
2011 f150 5.0l a/t,the trans shift points are all wrong(3/4shift is really fast)
RE: stock and 87 perf tunes
OK, we're checking it out.
as long as the trinity is currently married to the car, simply load the custom tune using dsdl and then flash it to the truck.
Tahnks
Tahnks
you got this error on DSDownloader?
it happens when you select your stock tune when prompted to do so by DSDL?
