9t14b APP Part Throttle Shifts
midevil214
Post by midevil214 »
Upgraded 9R13 crom to 9t14b. The Predator lost 8%, 10% and 15% app shift adjustability from 1-2 shift. 2-3 shift lost 15%. Will these be added back in? Also wondering if 3-4 shift will ever get anything below 20%. The vehicle is a 2010 Wrangler auto. Most of the 3-4 shift issues happen in the 5-15% app range. 20% being the lowest dosent help much.
RE: 9t14b APP Part Throttle Shifts
thats all the adjustment available...the factory tables are set up that way.
midevil214
Was there a specific reason for removing the 8%, 10% and 15% (1-2 shift) adjustments from the new CROM? They were there in 9R13.
turns out they were wrong in the old rev, which is why they did not work properly, the values you see now are correct, and all that is available from chrysler.
drfeelgood
Post by drfeelgood »
Is this new crom (9t14b) for all U7137s? Specifically, I have a 2010 Commander Hemi. The 1-2 and less so the 2-3 shift have been jerky/hesitant at certain throttle openings in the last couple revisions. Will this new crom help that?
it will allow you to adjust the part throttle 1-2 and 2-3 shifts...
drfeelgood
Re: 9t14b APP Part Throttle Shifts
Does the latest revision of 9r13 from November have these 2010 shift fixes that 9t14b does?
no, looks like we need to release 9r14 ;)
drfeelgood
So, I see that 9r14 is now released. Is it the same as 9t14b that I already have, or should I update to 9r14?
Thanks!
yup, same.
