How Do I Modify a Custom Tune?
Posted: Sat Jul 14, 2012 6:01 pm
by rham48
I have a U7135 with a custom dynotune on my car, a 09 Challenger RT. I want to readjust my fan settings. Do I need to install the original tune first and then install the custom tune again and make the adjustments under Modify Tune? Or is there a way to adjust the fan settings without doing all this? I searched the forum but couldn't find what I was looking for. Thanks.
RE: How Do I Modify a Custom Tune?
Posted: Sat Jul 14, 2012 6:30 pm
by Mike_Levy
Depends if the tuner locked it or not.
Re: RE: How Do I Modify a Custom Tune?
Posted: Sat Jul 14, 2012 7:03 pm
by rham48
Mike_Levy wrote:Depends if the tuner locked it or not.
It's not locked.
RE: Re: RE: How Do I Modify a Custom Tune?
Posted: Sun Jul 15, 2012 11:23 am
by bhrodeoaz
If its not locked then you should be able to adjust the fan temp under modify tunes
Re: RE: Re: RE: How Do I Modify a Custom Tune?
Posted: Sun Jul 15, 2012 3:10 pm
by rham48
bhrodeoaz wrote:If its not locked then you should be able to adjust the fan temp under modify tunes
I am aware of that. My question is do I need to install the original tune first and then install the custom tune again and make the adjustments under Modify Tune? Or is there a way to adjust the fan settings without doing all this?
RE: Re: RE: Re: RE: How Do I Modify a Custom Tune?
Posted: Sun Jul 15, 2012 4:16 pm
by bhrodeoaz
just to be on the safe side , i would suggest returning it back to stock tune then do your normal tune selection then mod the parameters as to your liking then install that way there is no chance of it getting criss-crossed. I have had that happen on my ram--- and for my ram the only quick adjustments i can make is tire size , if i wanted to adjust i have to install the tune again. There is also the option of just reprogramming your car without installing the OE tune--- it would be quciker so you would basiclly reflash the pcm with your modded custom tune and you wont have to reinstall the stock tune
