My FAN is running 24/7 U7135
ADSRT
Post by ADSRT »
Hey guys iam having my fan running 24/7 with the 93 Performance CAI Did any one adjust the fan setting in the predator ? if yes what did u do? And today i tried one thing i have checked my stock setting in the diablo i saw the fan settings as follow :
226.39 degrees For Hi speed fan
217.39 degrees For Low speed fan
Then i checked the 93 Performance CAI tune and got in to the modify tune and saw the setting different they are :
199.89 degrees For Hi speed fan
190.90 ( not sure) degrees For Low speed fan
So do i have to adjust both to make them equal so the fan wont be running always ? If yes then i did it and it didnt work still my Fan is running and running.
Iam using the latest update 8r17.
Any help would be appreciated.
terremoto09
RE: My FAN is running 24/7 U7135
Post by terremoto09 »
Try to do this I try and work perfect with my R/T
Fans off
High MPH HS ON - 226.39
High MPH LS ON - 217.39
High MPH MS ON - 226.39
Low MPH HS ON - 226.39
Low MPH LS ON - 217.39
Low MPH MS ON - 226.39
ON
HS - 226.39
LS - 217.39
MS - 226.39
and download the new revision u7135-8r17 (crom) 864k
I'm using a bit lower fan temps then that.
HS - 222.39
LS - 203.39
MS - 217.39
BUZ-CCC
Re: RE: My FAN is running 24/7 U7135
Post by BUZ-CCC »
Mike_Levy wrote:I'm using a bit lower fan temps then that.
HS - 222.39
LS - 203.39
MS - 217.39
IMHO I would set lower temp higher at least 10 degrees the way you have it set now your LS fan will be on all the time as stock stat is 203 its listed but we have no MS so set that same as high setting. As I posted in another thread DS set there LS fan 10 degrees higher then 180 stat and HS fan 19 degrees higher. Chrysler has real high settings for fans????
HS 222
MS 222
LS 213
ADSRT
Post by ADSRT »
terremoto09 wrote:Try to do this I try and work perfect with my R/T
Fans off
ON
HS - 226.39
LS - 217.39
MS - 226.39
Thanks i did the latest update changed the Fan setting in the modify tune ( 93 perf CAI) but still am getting the fan to work continusly ! is that cuz i have an export model SRT8 and with a different T-stat than the 180 degree ones which diablo is modifed to work with ? should i change my T-stat ? please help i love this product but this fan is driving me crazy :(
atttaboy
RE: Re: RE: My FAN is running 24/7 U7135
Post by atttaboy »
Yes , change it to 180°
05 Ram 1500
Quad cab
4X4
Blueprinted 5.7 hemi
all forged
8.8:1 comp.
STS turbo kit
Liquid intercooler
Ford cobra injectors
14lb boost (just 5# till tuned)
Innovate LC-1 wideband
crazylikeacharger
Post by crazylikeacharger »
MY high fans kick on when im sitting for awhile so i need to adjust it more
