Intune goes into Remote Control Mode, Why?
Mike'sLS3
Post by Mike'sLS3 »
When I plug my Intune to my PC it will automatically go to "Remote Control Mode" and the center spins around the D.S. logo as if it is trying to load or send data. I cannot back out of it. Then I unplug it and reconnect and it resumes back to the "Remote Control Mode". The top of the Intune reads RPC the bottom says "Thank You"? Why is the Intune doing this? :?
RE: Intune goes into Remote Control Mode, Why?
what software is running onthe PC?
DSDownloader?
Dataviewer?
Something thats trying to talk to a com port?
JonDiablosport
Post by JonDiablosport »
do you have dataviewer open on your computer?
Diablosport Tech support
p: 561-908-0040
F: 561-908-0048
rdss
Post by rdss »
Mine does that when I have the Dataviewer open as well. Just disconnect it when it connects to the DV software.
2010 GMC Sierra 5.3
K&N Aircharger
Mike'sLS3
Re: RE: Intune goes into Remote Control Mode, Why?
Post by Mike'sLS3 »
mikel wrote:what software is running onthe PC?
DSDownloader?
Dataviewer?
I have DataViewer 3.3 and DSLogRedux. It happens when I have DataViewer running, but not when I boot up the Intune by itself. It started to happen after the last update. Priro to the last update I always opened DataViewer first while booting up the Intune.
The Intune says its up to date with:
Firmware: lr02b
Gm: lr0lh
What is the difference between the DataViewer and DSDownloader?
2008 corvette coupe.
Mike'sLS3
Post by Mike'sLS3 »
JonDiablosport wrote:do you have dataviewer open on your computer?
Yes, but prior to the last update I had no issues with both DataViewer 3.3 and Intune running at the same time.
The "Remote Contro Mode" occurs when the Intune and DataViewer are running at the same time or the DataViewer is started after Intune has booted. In either case, I have to unplug the Intune for the "Remote Control Mode" to stop.
Once I unplug the Intune and reboot its fine as long as DataViewer is not running.
This does not occur with DSLogRedux software running with the Intune.
Mike'sLS3
Post by Mike'sLS3 »
rdss wrote:Mine does that when I have the Dataviewer open as well. Just disconnect it when it connects to the DV software.
I agree, it's just strange that is occured after the last update?
rdss
RE: Re: RE: Intune goes into Remote Control Mode, Why?
Post by rdss »
Mine has done it from the first time I had my inTune plugged in and DV open.
2010 GMC Sierra 5.3
K&N Aircharger
DVs job is to connect to any of our tools that are plugged in, so this is totally normal behavior...
