autostick and spark questions
Posted: Wed Aug 01, 2012 8:44 pm
by woodrow500
A couple more questions and I should be good to go, I cannot find this info in my instructions or anywhere else so here it is..
'09 Challlenger SRT8
Autostick upshift menu question
cancel
stock
mode1
mode2
mode3
What are the modes? I didn't click on any of them because I didn't know what they did.
spark questions
Spark must be adjusted in wide open throttle MET spk and wot spark parameters by the same amount.
What is wot MET spark ?
RE: autostick and spark questions
Posted: Wed Aug 01, 2012 9:22 pm
by Mike_Levy
Its MBT spark. It stands for Maximum Brake Torque.
http://en.wikipedia.org/wiki/Maximum_brake_torque
Posted: Thu Aug 02, 2012 9:25 am
by woodrow500
Thanks Mike
Re: autostick and spark questions
Posted: Thu Aug 02, 2012 3:46 pm
by ricks
woodrow500 wrote:A couple more questions and I should be good to go, I cannot find this info in my instructions or anywhere else so here it is..
cancel
stock
mode1
mode2
mode3
They are attempts to turn off the way the transmission automaticly up-shifts when you hit the shift point. On the 08's you could select this feature, and when in autostick, the car would not shift by itself. You had control of holding it in gear.
I have not tried it with the past few Predator revisions, but with the older revision I run, none of them gave me the Hold-in-Gear.
You can try them one-by-one and see if they have any effect on your car.
RE: Re: autostick and spark questions
Posted: Thu Aug 02, 2012 8:44 pm
by woodrow500
Thanks Rick,
I think I will let it alone so it can make its upshifts when it needs to so as not to take a chance of over reving it. I pretty close to the edge with a stock block.
Steve
Posted: Thu Aug 02, 2012 9:39 pm
by Mike_Levy
How close are you really? I made just under 600 with the stock 6.1 bottom end. There are guys with superchargers running over 800. You're gonna grenade the tranny, way before the block. Been there, done that, have a spare sitting in the garage that I can't use.
Posted: Fri Aug 03, 2012 7:14 am
by woodrow500
I don't make that kind of power Mike, more like 437 at the wheel @ 6200 and thats where the dyno operator cut the test off at. I was told by the dyno Co not to go past that and they didn't say why. It was done near Chicago in '09 I see. Another knowledgeable guy on the forums said that it would probably be ok to 6500 with the stock block. I am new to Mopars and trying to do what I am told as not to create problems. I do have forged pushrods I see now in the paperwork from the guy I purchased the car from. Shifting at 6400 now but was also told the cam that I have might be more happy at 6800. 6400 seemed to have woke the car up, I was surprised. Peak torque is at 5200. I hear builder Bill has a TCM to take it to 6500 but thats as far as I would go. Based on how the car responded when I went to 6400 I would say it may like 6500.
