Suggestions for tuning..
Insults
Post by Insults »
I've got a 2004 Chevy 2500HD 6.0L lifted 9" on 37's, 4.10 gears, K&N intake and true dual exhuast also..
I run the 87 octane tune, and the only parameters i've really messed with is the tire size and injector slope (I've got it at -1). Do you have any suggestions for other things i could mess with to get the most out of the engine.. for example there's a option to have it run more lean or more rich, should i leave that alone?, same with shift points, etc. Any suggestions on what i should adjust would be helpful..
rmck490
Post by rmck490 »
The best suggestion I could give you is get a custom tune from Lew (06MonteSS). He can hook you up with all your needs in a tune. His custom tunes are awesome.
If you want to do it yourself, I'll let others chime-in for their suggestions.
2000 Chevy Silverado 1500 Z71 4WD ECSB 5.3L
U7198 ver 9r17
Diablew Tuned
K&N CAI
Corvette Servo
