Common Parameter Acronyms
johnc
Post by johnc »
These will be added to the help system in the DataViewer with the next release. If there are any missing (or incorrect, heh) post a reply.
Example 1: IN MAN EGR MASS
Intake Manifold Exhaust Gas Recirculator Mass
Example 2: T CYL VE MOD
Cylinder Temperature Volumetric Efficiency Model
11 - Bank 1/1
12 - Bank 1/2
21 - Bank 2/1
22 - Bank 2/2
A2D - Analog to Digital
ACC - Accumulated or Accelerator (depending upon context)
ADAP - Adaptive
ADV - Advance
AF - Air to Fuel (Ratio)
AMB - Ambient
AVE - Average
BARO - Barometric (Pressure)
BATT - Battery
CALC - Calculated
CAT - Catalyst (referring to catalytic converter)
CNT - Count
CTP - Commanded Throttle Position
CORR - Corrective
COT - Catalytic Over Temp (protection)
CURR - Current
CYL - Cylinder
DEF - Defined or Default (depending upon context)
ECT - Engine Coolant Temperature
ENG - Engine
ERR - Error
EXH - Exhaust
FA - Fuel to Air (Ratio)
FACT - Factor
FBK - Feedback
FILT - Filtered
FRAC - Fraction
FT - Fuel Trim
HTR - Heater
HTR11 - Heater Bank 1/1
HTR12 - Heater Bank 1/2
HTR21 - Heater Bank 2/1
HTR22 - Heater Bank 2/2
IAC - Idle Air Control
IAT - Intake Air Temperature
IDL - Idle
INTK - Intake
IS - Injector Slope
KNK - Knock
KPA - kPa ( kilo Pascals)
KR - Knock Retard
LT - Long Term
MAF - Mass Air Flow (sensor)
MAN - Manifold
MAP - Manifold Absolute Pressure
MOD - Model
MULT - Multiplier
02 - Oxygen
02S - Oxygen Sensor
PHI - Phi (fuel-air ratio relative to stoichiometric)
P-RAT - Pressure Ratio
PRATIO - Pressure Ratio
PRES - Pressure
PCV - Positive Crankcase Ventilation
PDL - Pedal
PE - Power Enrichment
POS - Position
POSN - Position
PRG - Purge
RAT - Ratio
REF - Reference
RET - Retard
RPM - Revolutions Per Minute
SNS - Sensor
SPK - Spark
ST - Short Term
T - Temperature
TB - throttle body
TEMP - Temperature
TGT - Target
THR - Throttle
TIP - Turbo Inlet Pressure (or Turbine)
TOT - Total
TPS - Throttle Position Sensor
TRQ - Torque
V - Volts
VAC - Vacuum
VE - Volumetric Efficiency
VEH - Vehicle
johnc <at> diablosport.com
RE: Common Parameter Acronyms
dunno if you need any of these in the dataviewer or not, but here...
IS - Injector Slope
FT - Fuel Trim (i see you already have the LT and ST)
TB - throttle body
KR - Knock Retard
johnc
Post by johnc »
Thanks. Added.
pjstrifas
Post by pjstrifas »
What about ACT? I see a parameter "TRQ ACT" in the predator.
calbert
Post by calbert »
And, WOT. Finally, figured out Wide Open Throttle.
calbert
Post by calbert »
You guys should have someone create a rap song using these terms. LOL
ok... you've been elected!!
let us know when that's ready... ;)
:lol:
calbert
Post by calbert »
Hahaha.... I can't rap for beans. I'm a PM, IT field.
hahaha... my day job is an internet/web developer... ;)
this stuff is a side/second job for me... hehe...
calbert
Post by calbert »
Really? Do you work on cars or something? You know alot about vehicle tuning. Seems like a FT job.
hahaha.. I agree, it does seem like a full time jobs sometimes... :lol:
but nope... this is my 2nd job - been doing it for just about 5 years now... it's my "hobby"... ok, so maybe I'm a little more obsessed with it than most hobbyists :lol:
capeyork
Post by capeyork »
PTC ?
mfitzs70
Re: Common Parameter Acronyms
Post by mfitzs70 »
TDC=Top Dead Center
smkn_cobra
Post by smkn_cobra »
hey, Kind of super old thread. if it matters 2016 f150 2.7l eb
on the trinity 2...
Boost Abs
Des Boost
Lambda B1
Lambda CMmd
Thanks :crashing:
Boost Abs this is actual boost at the manifold
Des Boost this is how much boost the pcm is asking for.
Lambda B1 this is actual Air/Fuel ratio at bank 1 wideband
Lambda CMmd this is the AFR the pcm is commanding
Return to “DataViewer/DV2”
