Trouble Light
Posted: Mon Nov 05, 2007 10:41 am
by Neubium
Diablo CAI performance tune installed SRT Charger. So, I am driving home last night and a little warning light comes on my dash. The icon of a little engine just sitting there to let me know something is just not right. I was thinking just maybe it was fluke, therefore I stopped the car and restarted to see if it would clear but no luck. This morning same light just sitting there very solid and not going away. Any suggestions?
RE: Trouble Light
Posted: Mon Nov 05, 2007 11:41 am
by Tyrant
use the diablo to read the trouble code, that way it'll be much easier to help you out :)
RE: Trouble Light
Posted: Mon Nov 05, 2007 4:10 pm
by Neubium
Trouble code PO128 "Coolant thermostat". I reset the error code via the Predator, however, my guess is this will continue due to the 180 thermostat installed. Are there others experiencing this problem? What can be done to eliminate the issue?
RE: Trouble Light
Posted: Mon Nov 05, 2007 4:42 pm
by Tyrant
well i think it could be that your car is not reaching the required temps fast enough (persay) could e a reason.. although i'm sure others will chime in :)... are the ambient temps low where youre at?
RE: Trouble Light
Posted: Sat Nov 10, 2007 2:14 am
by 10SecS4
It is not unusual to get that code with a cooler thermostat. Like Tyrant said, it's due to your engine's inability to get up to operating temperature within a certain amount of time. You can clear this code with your Predator by going into the Diagnostics section.
I think Diablo may be working on a fix for this so that the code does not pop up. If they're reading this, I'd also like a fix for that annoying low tire pressure monitoring alert. That thing comes on like every 10 minutes with the drag radials and really irks me.
RE: Trouble Light
Posted: Mon Nov 12, 2007 12:54 pm
We are looking into a fix for the coolant CEL, but not sure about the TPS monitors.
