Predator u7136 Update Corrupt
Posted: Fri Aug 24, 2012 11:37 pm
by angcor02
I plugged my predator in and ran the 9r07.crom update, everything says it was successful but when the predator reboots it tells me the app is corrupt or missing. Any suggestions on how to fix this?
Re: Predator u7136 Update Corrupt
Posted: Sat Aug 25, 2012 11:28 am
by Mike_Levy
Redo the update. You'll probably have to connect using Legacy Connect and choose what port its connected to.
Posted: Sat Aug 25, 2012 4:15 pm
by angcor02
I erased the update and redid it and reloaded it to the predator also, same error, app is missing or corrupt.
Posted: Mon Aug 27, 2012 11:50 am
try redownloading the file from our site?
Posted: Mon Aug 27, 2012 12:35 pm
by angcor02
@MIKEL, I did, thats what I meant by I erased it and redid it. Same outcome.
Posted: Mon Aug 27, 2012 12:53 pm
try the file I just emailed you...
Posted: Fri Oct 12, 2012 2:57 pm
by jlcolvin
I am having this same issue on my U7136 Predator. I have retried multiple times with the same result of: "The application is missing or corrupt."
Thank you,
Jason
Posted: Fri Oct 12, 2012 5:20 pm
jlcolvin wrote:I am having this same issue on my U7136 Predator. I have retried multiple times with the same result of: "The application is missing or corrupt."
Thank you,
Jason
attached.
Posted: Fri Oct 12, 2012 5:51 pm
by jlcolvin
That fixed it, thank you very much.
Posted: Mon Jan 23, 2017 11:24 pm
by omaralz
mikel wrote:try the file I just emailed you...
I am having the same issue here but when I am at the ds downloader app and is at the middle of the prosess downloading I get a error message that says I did not se the tool in the selected serial port, is the tool connected, is the serial port connection correct, is the tool powered up and waiting an the main menue screen....the tool Is connected to my pc and its powered...help please....
Posted: Tue Jan 24, 2017 1:56 pm
omaralz wrote:mikel wrote:try the file I just emailed you...
sounds like a possible bad USB to serial cable issue
