87 Octane tune question
BlackZ71Silverado
Post by BlackZ71Silverado »
Is it possible to use 89 octane fuel with the 87 tune? Was told by someone from Black Bear Performance that the trucks should not run anything less than 89 octane even with the stock tune. Even though GM recommends 87 on the sticker. If the tune won't perform properly with the 89 octane, what changes would have to be made to correct the tune?
2010 Silverado Ext.Cab 5.3L
MBRP exhaust
AirAid MIT AEM filter
Black bear Performance Tuned
2008 Silverado Ext. Cab 6.0L Vortec Max
GMPP exhaust
GMPP CAI
Black Bear Performance Tuned
Re: 87 Octane tune question
You can always run higher then the tune specifies, but never less. If the tune is designed for 87, then you can run 87 and up. If it needs 89 stock, then the timing is probably retarded to use 87.
BlackZ71Silverado
Appreciate it Mike, thanks.
MBRP exhaust
GMPP exhaust
GMPP CAI
Oldsaltydog
Post by Oldsaltydog »
I run 87, and 89 sometimes with my 87 diablew tune but now I'm addicted to his 91 octane tune it pulls from the bottom all the way to redline and I use 93 with that tune.
Oldsaltydog
2007 corvette c6
yeah, I would run at least 89 octane man... 87 gas just sucks plain and simple...
Bacfire
Post by Bacfire »
87 get you from point A to point B just fine.
91-94 get you there, leaving the competitor behind on your way.
If you can afford to run higher octane, do it. If money is an issue, then you gotta do what you gotta do!
2006 Chrysler 300c Awdsome
Intune I-1000
Afe Stage 2 CAI
Billet Tech Catch Can
Egr Delete
Corsa Sport Cat-Back
Tranzformer
Coolit
noESP
JBA Catted Mids
If money is an issue, you're driving the wrong car/truck. If you can't afford to run and mantain the car as intended, you can't afford the vehicle. Get something cheaper rather then killing it.
BlackZ71Silverado
Money is not an issue at all...Was just wondering if the use of 89 octane would have any ill effect with the 87 tune, that's all.
MBRP exhaust
GMPP exhaust
GMPP CAI
rdss
Post by rdss »
Mike_Levy wrote:If money is an issue, you're driving the wrong car/truck. If you can't afford to run and mantain the car as intended, you can't afford the vehicle. Get something cheaper rather then killing it.
Killing it using the recommended octane from the factory?! I don't quite understand that statement. I do agree running better gas is better for performance, but Lew has improved my mpg (by 1-1.5 mpg), power and driveability on 87 octane. When I didn't have my Sonic and was driving the truck every day running 87 was saving me between 20-30 bucks a month in gas (93 is almost 30 cents more than regular in NE Fl). If your not using the country store or SAMs/Walmart 87 and using quality gas then I don't see the problem.
2010 GMC Sierra 5.3
K&N Aircharger
BlackZ71Silverado wrote:Money is not an issue at all...Was just wondering if the use of 89 octane would have any ill effect with the 87 tune, that's all.
nope, will be better for you actually... so yeah, I'd run 89 in it...
They only recommend it because thats the minimum it will run on, and people are cheap. Doesn't mean its good for it or that the truck is happy with it.
Saving $20-30 is nothing. When a motor costs $5,000, whats $30/mo? Thats almost 14 years to cover the cost of a motor.
Bacfire
Post by Bacfire »
Well, i dont think running lower octane gas will kill an engine. Most of them are probably made based on the fact that people will run them this way.
Now, engine maintenance is something that most people dont do correctly, and that is the real killer in my opinion!
Intune I-1000
Afe Stage 2 CAI
Egr Delete
Tranzformer
Coolit
noESP
JBA Catted Mids
Lower octane causes detonation, detonation destroys pistons. If chipped and burned pistons aren't destroying an engine, whart is? A connecting rod through the side of the block?
Bacfire
Post by Bacfire »
I know about detonation, but most vehicle you see on the road are driven by old people not using half of their engine. Sure if you tune and race your car on low octane, youll have problem, but for everyday application...i dont think youll see much engine going to hell?
Intune I-1000
Afe Stage 2 CAI
Egr Delete
Tranzformer
Coolit
noESP
JBA Catted Mids
rdss
Post by rdss »
Mike_Levy wrote:Lower octane causes detonation, detonation destroys pistons. If chipped and burned pistons aren't destroying an engine, whart is? A connecting rod through the side of the block?
The Auto Manufacturers must be replacing tons of motors running on 87 then..... I'm pretty sure that most modern motors pull timing to protect against this and if your custom tuned and detonating on 87 you might want to find another person to tune your vehicle.
2010 GMC Sierra 5.3
K&N Aircharger
