Bad Misfire 02' LS1 Camaro SS (log file inside)
Posted: Mon Sep 17, 2012 8:53 pm
by jfl330
The car shook it was misfiring so badly. I plugged in the Predator and grab a log file kind of after the fact, but the misfires are still there.
All misfires were on Bank 2. Across all four cylinders.
Trying to figure out if it is ignition or fuel related.
If someone can take a look at the log file, I'd be greatly appreciative.
Jon
Re: Bad Misfire 02' LS1 Camaro SS (log file inside)
Posted: Tue Sep 18, 2012 8:33 pm
by 06MonteSS
I just replied to your email too man...
just checked that log man.. and your bank 2 (passenger side) fuel trims go from 0 to being pegged at +25... the drivers side is fine, numbers look ok...
so that front right O2 sensor is still not right man... it's either the O2 sensor itself, or it's the wiring... or, do you have headers? check the right/passenger side header/exhaust for any cracks, leaks, not bolted tight, etc etc....
but yeah, something is still not correct with that passenger side man...
