P200e Code after Predator Install
mkbduff
Post by mkbduff »
Anybody had any problems with P200E code after installing the Predator Tuner on a 2008 F250. Did not go to the extreme , just installed the economy to try to get better fuel milaege, Ran great for a week, then ended up sitting on the side of the road waiting for a tow truck because the P200E FORD - Catalyst System Over Temperature (Bank 1) code. Any suggestions??
Re: P200e Code after Predator Install
havent seen that, what tune was loaded?
mkbduff
Post by mkbduff »
The tuner I used was the U7164 Predator for 2008 to 2009 6.4L Powerstroke. At this point I am at the mercy of the dealership to tell me what happened. Should know something by tomorrow. I will keep you updated.
mkbduff
Post by mkbduff »
Looks like the DPF filter was clogged up. The programmer wasnt letting the Clean Exhaust Filter do its job. This was an expensive lesson learned.
After reading all the forums, which I should have done pefore I purchased, this tuner still has a lot of tic's. I will be keeping the stock tune until I can find something a little less glitchy.
mkbduff wrote:Looks like the DPF filter was clogged up. The programmer wasnt letting the Clean Exhaust Filter do its job. This was an expensive lesson learned.
these issues were fixed in the most recent software updates...
