Torque Management on 05 dodge ram 1500 4.7l
Andrew.S
Post by Andrew.S »
My intune is upto date according to update software, i installed the diablo tune no customized parameters and from a dead stop there is still no power for about 4 sec. according to my research on these forums i believe T.M. is still enabled. What do i need to do to remove the T.M restrictions.
Re: Torque Management on 05 dodge ram 1500 4.7l
can you post up the backup and last tune written files please?
Andrew.S
Post by Andrew.S »
here they are.
TCM_56028953AEA_LastTuneWritten.drg
(115.46 KiB) Downloaded 209 times
TCM_56028953AEA_Backup.drg
(115.46 KiB) Downloaded 241 times
can you post the PCM tunes please?
Andrew.S
Post by Andrew.S »
What do you mean by pcm tune those were taken off of the intune tune folder
heres my info.xml file if that help
info.xml
(482 Bytes) Downloaded 311 times
thats all you have there?
please post the info.xml file as well.
Andrew.S
Post by Andrew.S »
Attached on last post
Andrew.S
Post by Andrew.S »
So I am guessing that tech support has no answer for this which is why their has been no reply at all...Thanks for the customer service.
Still waiting for the PCM tunes...
Oldsaltydog
Post by Oldsaltydog »
You need to send them the PCM tunes they are what control your engine and make it run
Oldsaltydog
2007 corvette c6
Andrew.S
Post by Andrew.S »
I have posted everything that was able to be transfered from to tuner to the computer there were no other files.
go back and restore the stock tune, then try reloading the tunes, does it ask you to update the PCM?
Andrew.S
Post by Andrew.S »
Ok After retuning stock tune and tuning I forget i think diablo tune here is the pcm
PCM_56028942AF_LastTuneWritten.drg
(57.69 KiB) Downloaded 258 times
PCM_56028942AF_Backup.drg
(57.66 KiB) Downloaded 331 times
Slacker
Post by Slacker »
Andrew.S wrote:What do you mean by pcm tune . . .
What part of this poor guy's original question was not English enough to understand?
Andrew.S
Post by Andrew.S »
So all other post have a answer...is there a reason mine hasnt been pcm tunes have been uploaded and downloaded.
