Rokktech sensor and predator?
mopeman
Post by mopeman »
I just bought a predator tuner and have the rokktech timing sensor currently installed. Can I run these together, or should I install my stock timing sensor?
Re: Rokktech sensor and predator?
what is that exactly?
Im guessing its an inline timing device?
mopeman
Post by mopeman »
mikel wrote:what is that exactly?
Yes, it's a modified crank position sensor, it advances the timing. Just don't want to put to much timing into the motor. Also, is it suppose to smoke with the mild tune/perfromance tune? Thanks for the help! :D
ok, should work fine.
smoke is an odd deal, some trucks smoke like crazy, some dont smoke at all.
It depends heavily on the how well the rest of the systems inthe process are working.
mopeman
Post by mopeman »
mikel wrote:ok, should work fine.
The Rokktech sensor adds 2 degrees of timing in the most advanced setting, just wanted to make sure it was good to go. I think some of the smoke has to be because I have the 6 speed manual.
