Having Trouble Setting up LC-1
I am following the instructions in the Trinity manual as well as I think I should. I am letting analog two configure as volts, then range from 0 to 5 volts. I am then creating an additional parameter named AFR that utilizes analog two and scales from 7.350 to 22.390 and applying this to a small digital gauge I have created named Wideband. I get a static reading when I run the engine.
Re: Having Trouble Setting up LC-1
I can't help other than to say, have you watched the video on Speedy's Garage? I know it takes you through the set-up step-by-step. Maybe it will tell you something.
http://www.speedysgarage.net/challenger ... _index.htm
Rick
2009 Challenger SRT
Kenne Bell 2.8LC Supercharger
2009 Challenger SRT
