Hi i have an 01 gmc sierra 2500hd 4x4, i have a U7198 version V.9r17. I have the both catalytic converters removed, i used the tuner to disable the temp fueling adjustment and bought simulators for the o2 sensors to keep the cel off. However i still get codes p0140 and p0160 for insufficient o2 sensor activity. Is it possibe to get a custom tune to remove all of the rear o2 sensor codes?
Thanks!
custom tune/catalytic converters removed
kevoscamaro
Re: custom tune/catalytic converters removed
Do you have COT in your menu? Some of those codes are in there if you have that option.
Fast-Orange
I am able to adjust COT, i set it to 1200 when i modify the tune. There is no code listings or anything like that to modify unless im looking in the wrong places.
kevoscamaro
I have an old old predator. My settings are diff. That's where I turnt mine off but I also have an actual o2 setting too. Prolly have to pm 06montess. He does tunes and knows 1000 times more stuff then I do.
yes, I can certainly get you hooked up! you have the pc interface kit for the predator right?? that's the usb/serial cable and power adapter you need so that you can connect it to your Windows PC in order to import/export tune files...
I can do just the trouble codes and related items disabled for only $35...
or I can do a complete custom tune for your vehicle (including the codes), for only $135...
With the custom tune, you'll gain even better/quicker throttle response & acceleration, stronger/harder pull, smoother & quicker power delivery throughout the rpms, etc... and sometimes, maybe even a little better gas mileage - if you can keep your foot out of it! hahaha...
as far as gains go or track times, it all depends man.. absolute hp/tq gains are hard to predict... every vehicle is different... even if they're the same and have similar mods... location/weather, fuel used, elevation/altitude, etc etc all play a role... the same holds true for mileage gains - those variables, plus driving habits/style, how much highway vs. city driving, etc all make a difference.... you could gain no mpg increase, or you could gain up to about 3 mpg increase... tough to say due to the variables in play...
I CAN tell you that you will have a very noticable performance difference/gain over and above the canned preset diablo tunes...
I have gained people anywhere from 15-39hp, and 12-23lb. ft. torque, and 1-3mpg - over and above what the diablo tunes give you to start with... again, obviously mods, fuel used, etc all played a role in who gained what...
What I'd need from you is a copy of your "original backup" stock tune file, a copy of the "last tune written" tune file, and the paypal (there are "Buy Now" paypal buttons on my site), and that's it... then we're good to go. and I can usually have the initial custom tune done and sent back to you within 24 - 48 hours from the time that I receive everything.
Here's info about my custom tuning:
http://www.diablewtune.com/
there are links on there to all the info/instructions and programs you'll need - i.e. what tune files I need, how to export/import tune files, link to data logging info/instructions, paypal "Buy Now" button etc... as well as a link to just a small sample of just some of the "Testimonials" I've received from people I've done my tunes for - makes for good reading, hehe.
once I get the initial custom tune done and sent back to you and you install it, I have you put on some miles for a couple days so that the fuel trims and other items get relearned by the ecm and settle in, and then I'll have you do a data log for me so I can check the fueling/timing/etc and do some fine-tuning adjustments... Send you an updated tune file, have you do another data log to check things... make any more adjustments for part-throttle if needed, and it's on to the WOT fun! hehe... Then I have you do a WOT data log for me, etc.
Thanks for asking man, I appreciate it!!
please feel free to hit me up if you have any questions...
Thanks!
Thanks!
Fast-Orange
Well its my second truck (I bought an lbz dmax which i also have a predator in) and im trying to sell it, if it doesnt sell tomorrow ill be getting the tune for the cats removed forsure. Also yes i have the serial cable, have the stock tune and my modified tune saved to my comp already. Ill be letting you know shortly thanks a ton!
Also a little info truck has k&n intake, t/b spacer, true dual flo pro exhaust beleive 2 1/2" id have to double check, 3" body lift with a 2" leveling kit with 35's and i get about 20L per 100km haha. Do you tune diesels as well? (edit i see in your sig pic that yes you do tune diesels.)
Fast-Orange wrote:Well its my second truck (I bought an lbz dmax which i also have a predator in) and im trying to sell it, if it doesnt sell tomorrow ill be getting the tune for the cats removed forsure. Also yes i have the serial cable, have the stock tune and my modified tune saved to my comp already. Ill be letting you know shortly thanks a ton!
well, diablosport makes programmers that work on diesels, yes.. they come with preset tunes on them for different HP gains/tunes... but there is no custom tuning available for GM diesels... you can use the 60-100hp tunes/adjustments that are on the programmer for that vehicle...
