CAL_ID FBBT057
Posted: Thu Oct 25, 2012 3:41 pm
by niko
Hello Friends have a little problem.... i update mi predator U7140 and now when i connect obd in my car exit this: Your veicle is not in our database.contact your dealer for a free update. your CAL_ID is "FBBT057"
My car is a 2005 Mustang V6 base
info tool:
serial: 900a831
Part: U7140 Stang05
Version: V9.9r03
hardware: univ-rev2
bus: Can
Born : 02-26-2010 13152
Bus test: +
please help me :lamer:
Re: CAL_ID FBBT057
Posted: Thu Oct 25, 2012 5:28 pm
you need to update that tool to the latest revision.
Re: CAL_ID FBBT057
Posted: Fri Nov 02, 2012 7:34 pm
by niko
I did update as recommended and now my car in the shop with empty unit without map inside, predator does not know cars and car died! Ford has solved only problem with new remapping original problem returned .... you spoke Monday with my friends of the problem in Italy .... Remember this? We also forced to restore original backup with tails but no result, what can I do with this predator erases memory? I groped a few test on pc? :crashing: thanks MIKE
Re: CAL_ID FBBT057
Posted: Mon Nov 05, 2012 7:08 pm
you can send me the pcm and I will fix it.
Re: CAL_ID FBBT057
Posted: Tue Nov 06, 2012 5:35 pm
by niko
mikel wrote:you can send me the pcm and I will fix it.
I restored the original map by ford service center and my car is fine now .... I think that the predator may have problems!
according to your experience, the predator can give this kind of problem, or more simple and that the problem is on my PMC?
the car is in italy and this is a big problem :oops:
