my new diablosport predator u7165
I wanted to know if i need to download any new updates for this new programer,and Is there any custom downloads for my applicaition/mods that i have on my truck 2006 ford f250 deisel 6.0 liter. has cold air intake and 4"exhaust cat deleat pipe straight thru muffler thanx very much for your time BMAN ([email protected]) p.s. does it cost extra for custom downloads?
Re: my new diablosport predator u7165
what revision is on it currently?
I have the 9r14 program that came with the unit!!! I see that there is an update to 9r15 WHAT will that do as a differance to the tune!!!
Allso Im experencing the engine light coming on when I hit the pedel to the floor for a period of time-or when I have it on cruze control and hits a steep Incline/hill- the predator tool can clear the error code and make the light go out,but if i want to know what the error is It says no error codes Found. I have had the truck at the dealership for an engine problem about 6 months or less ago and in looking at the papper work i see that they had an error code of po611 they tested the EEC dropping down to 38 volts,spec is 48 volts,they state that they replaced /installed half shell per tsb test/test drove/passed!!!! can you or some one help me with this on going engin light problem. A shop has a fix that you send them the unit and they will rebuild it to stock specs or upgrade the unit to 58 volts /I think the site said.... I have an extended warranty on the truck but what is the best solution to this problem and or is the tunning tool causing this problem????? I want to get to the bottom of this situation a.s.a.p. Thanx (Please help with a sollution)
Allso Im experencing the engine light coming on when I hit the pedel to the floor for a period of time-or when I have it on cruze control and hits a steep Incline/hill- the predator tool can clear the error code and make the light go out,but if i want to know what the error is It says no error codes Found. I have had the truck at the dealership for an engine problem about 6 months or less ago and in looking at the papper work i see that they had an error code of po611 they tested the EEC dropping down to 38 volts,spec is 48 volts,they state that they replaced /installed half shell per tsb test/test drove/passed!!!! can you or some one help me with this on going engin light problem. A shop has a fix that you send them the unit and they will rebuild it to stock specs or upgrade the unit to 58 volts /I think the site said.... I have an extended warranty on the truck but what is the best solution to this problem and or is the tunning tool causing this problem????? I want to get to the bottom of this situation a.s.a.p. Thanx (Please help with a sollution) Re: my new diablosport predator u7165
Need to know what the code is for in order to help.
Insert Clever comment here...
The unit does not give me the code! it says no error found.So I Guess When it come's up the next Time, Someone seggested to take the truck to a parts place like o'reilles auto parts or repair shop that they have a code reader!!! but I don't Know.... What Do You Think?
Hello You There????
You could try that yes. I just need the code it gives.
