06 mustang roush cai
ok, so i am curious... i have the ROUSH cold are intake, and it's not listed in the predator, should i set it on airaid, or k&n?? thanks
RE: 06 mustang roush cai
The Roush and Airaid cai's are the same. Remove the insert from the intake tube and install the Airaid tune. I have the same set up, great performance.
thanks for the help question: what should i remove??
There is a removable insert in the intake tube between the air filter and the throttle body. I believe the instructions say removal of this requires custom tune. The Airaid tune in the Predator is set up without the insert. Remember if you take the Airaid tune out and go back to stock tune, put the insert back in.
My apologies as I just noticed you have the V-6. Mine is the 4.6, so I'm not sure what I've told you is correct. I would suggest you re-post your inquiry and let Mike or Christy answer it. Sorry for any confusion.
Re: 06 mustang roush cai
06roushv6, we have tested the AirAid v6 intake in house and have developed a Maf curve and tune for it. We will be releasing it in the next revision. For now you should be able to run the Predator tune. Stay tuned for updates.06roushv6 wrote:ok, so i am curious... i have the ROUSH cold are intake, and it's not listed in the predator, should i set it on airaid, or k&n?? thanks
Kev
