Dashboard via SD Card
I got a dashboard from another Challenger owner and transferred to the Trinty via the SD card options. It load fine but it does not show up on either Monitoring or Logging. I know it is on the Trinity as I tried to reload it and it said it was there and asked of I wanted to rename it. Suggestions.
2010 Dodger Challenger R/T 6 Speed
Re: Dashboard via SD Card
ok...what vehicle does he have?
whatever vehicle he 'selected' to create that dash, its what you need to select to make it show up.
so, if he selects 08 / dodge/ charger/3.5, thats what you have to select, as its embedded inthe title of the layout itself
hope that helps.
hope that helps.
I will assume that if I change to match his then anything dashboard related will have to be redone? What about backups (original tune and mods to MPG)?
this affects only the dashes that are displayed....
same here, but now when i go to delete them, they keep reappearing?? how to delete??
