Cruise control lost after tune on 2008 6.4L
After installing the Extreme Tune on my 2008 6.4L my cruise control will not work. If I switch back to Economy or Factory it works just fine. Any idea what may be causing this or a fix. Latest updates are installed and the truck is on 37" tall tires, if that helps.
Re: Cruise control lost after tune on 2008 6.4L
can you post your calibration ID?
tech@diablosport.com
Unit 1:
8U7A-14C204-CH
Unit 2:
7U7A-14C337-AB
8U7A-14C204-CH
Unit 2:
7U7A-14C337-AB
what is the actual version shows onthe tool as well please?
Version: v.1r08c
Unit 1: 8U7A-14C204-CH
Unit 2: 7U7A-14C337-AB
Does this issue happen across all the tunes or just the extreme? Have oyu tried any of the others?
Insert Clever comment here...
It works about half of the time when it is on "Economy." It will work up to 45MPH on Extreme, after that it will not work at all.
He's still looking into this...
we'll have a new rev shortly to address this. Just need to finish up some other stuff in the database. I'll post it when ready.
Try this.
- trinity_ford_can_diesel-1t09al_update.crom
- (3.86 MiB) Downloaded 959 times
- Hillbilly1
Will this also work on my 2008 6.4L F350 as i am having same issue after the third day of installing trinity?
Do not demand that which you cannot take by FORCE!!!
WEll yes it will clear them but they will come right back. Due to stict EPA rules we don't change nor modify any of the emissions equipment.
- Hillbilly1
I have version v.1r09 is there a newer version to download because I have same problem w/ my transmission not wanting to shift out of first to second gear. Also my cruise control quits working after cruising and then accelerating.
please try the attached update guys.Hillbilly1 wrote:I have version v.1r09 is there a newer version to download because I have same problem w/ my transmission not wanting to shift out of first to second gear. Also my cruise control quits working after cruising and then accelerating. who has the best custom tunes for 2008 6.4L F350???????
- trinity_ford_can_diesel-1r09a_update.crom
- (3.86 MiB) Downloaded 972 times
