How can you tell if your truck already has perf module
Matttad
Post by Matttad »
Tried to load 2003 F250 6.0 just puchased and seviced by a local Ford dealer using Pedator U7160. Got message "Feature not supported on this vehicle, call tech support with Calid, reflash may be required." (Calid ' AKZ2AH19') (Last tune written "Original backup" "Factory MPH Limit" ) I also got "Did not see ignition turn on. Make sure you do not have a performance module" Could this truck already have a performance module? Could this be my problem? Thanks for any insight Matttad
ChrisDiabloSport
Post by ChrisDiabloSport »
Most likely you just need to update your Predator to the latest revision and everything will work fine. You can get the latest revision and the instructions on how to load it to your Predator from the following link.
http://www.diablosport.com/index.php?mo ... lay&pid=44
Thank You
Chris Johnson
1865 S.W. 4th Ave. Suite D2
Delray Beach Florida 33444
Phone: 561-908-0040
Fax: 561-908-0048
www.diablosport.com
Return to “Predator Ford Gas”
