U7158 - Harware Releases
h083221
Post by h083221 »
Hi
I just searched the postings but came up short on this one.
Is there any way to tell what version of hardware you have for the U7158 Lightning/HD Predator??
I noticed somewhere that if the unit has a black back ... it may be one of the newer versions ... but could not find which one. I believe there are 4 different versions??
I am looking at purchasing a used U7158 that has had the stock tune put back on the original vehicle (so I am good there) ... but I am concerned that if I get one too old ... it may be be compatable with all the current / future updates!! Is this a valid concern?? or can ALL of thew U1758 units accept the new updates??
Dean
RE: U7158 - Harware Releases
With the tool powered up look at the top line of the main menu to see what revision it is currently on.
kmac1
Re: U7158 - Harware Releases
Post by kmac1 »
h083221 wrote:Hi
Dean
Dean, to use the new revision you need the latest hardware. Most black backs have it but you must confirm by removing the cover and looking on the bottom of the board. You want hardware with Rev3 or Rev4.
Kevin@Diablo
h083221
RE: Re: U7158 - Harware Releases
Post by h083221 »
Thanks guys ... I decided to go the new route ... just to be on the safe side.
Regards
Dean
kmac1
Re: RE: Re: U7158 - Harware Releases
Post by kmac1 »
h083221 wrote:Thanks guys ... I decided to go the new route ... just to be on the safe side.
Not sure what you mean by "safe side"
The older revs will be updatable too, just takes time...
Kevin@Diablo
homestead_us
RE: Re: RE: Re: U7158 - Harware Releases
Post by homestead_us »
What does takes time mean? I bought my predator brand new in 05 and now I cant even install the new update because its too old. That jsut makes me want to to buy a new tuner from a different company.
Return to “Predator Ford Gas”
