Oil change warning popping up
Posted: Tue Nov 27, 2012 8:01 pm
by jeffsage
2012 392, Auto.
Installed Trinity 2 days ago. Change oil message popped up on evic today. I had oil changed about 1k ago. I have the latest update, as it was updated on 11/21.
Re: Oil change warning popping up
Posted: Tue Nov 27, 2012 8:48 pm
by Mike_Levy
Did they reset the warning when the oil was changed? Doesn't seem like it. Just reset it and don't worry about it.
Posted: Tue Nov 27, 2012 10:26 pm
by eric.hauptman
they probably forgot to reset the computer just turn the ignition to run pump the gas 3 times and then start the car all will be fine.
Posted: Tue Nov 27, 2012 10:42 pm
by MuscleCar
Your operators manual tells you how to reset the oil change message when the dealer forgets.
Posted: Wed Nov 28, 2012 1:15 pm
by SRTGR8T
to shut off oil change message all you have to do is, start the car, shut it off, then put ignition in run posittion without starting car, then pump gas 5 times and your set. start car and message is gone...
Posted: Thu Nov 29, 2012 6:59 am
by jeffsage
Thanks, everybody.
