Page 1 of 2
ABS Issue, can't update tire size on 2005 Durango
Posted: Mon Dec 17, 2012 11:46 am
by jackedmech
I recently bought Ram 20's and put them on my 2005 Dodge Durango HEMI and now I have a C1078 code and a flashing ABS light. I tried changing the tire size with my Diablo Predator Programmer and clear the codes, no joy at all. I took it to local shop and had them do all the checks and they said it is caused from the larger rims and tires and the computer just needed to be updated. Is there a update I can put on my programmer to fix this? Any help would be great.
John
Re: ABS Issue, can't update tire size on 2005 Durango
Posted: Mon Dec 17, 2012 12:10 pm
Im not familiar with an update to fix it, is the speedo correct?
Let me check with our dcx guru....
Posted: Mon Dec 17, 2012 1:30 pm
by jackedmech
Yeah, the speedo works, a little off. I just can't seem to get it to update the tire and rim size for some reason which should clear out my issue.
Posted: Mon Dec 17, 2012 3:21 pm
so, the Predator fails to change the tire size?
Posted: Mon Dec 17, 2012 3:26 pm
by jackedmech
Yep.
Posted: Mon Dec 17, 2012 3:30 pm
what revision?
Posted: Mon Dec 17, 2012 3:31 pm
by jackedmech
Additionally it will not read out the codes, not sure if this is normal, I have been going to Advance Auto to read the codes.
Posted: Mon Dec 17, 2012 3:37 pm
by jackedmech
Not sure on revision, I will check when I get home and let you know.
Posted: Mon Dec 17, 2012 8:42 pm
by jackedmech
V.9r09 is what I have. I have been trying to update it but it keeps saying can not downgrade.
Posted: Mon Dec 17, 2012 9:30 pm
by jackedmech
I just went through some of the old posts and figured what I was doing wrong updating, so I am set. I will try updating the tires in the morning.
Posted: Tue Dec 18, 2012 8:40 am
by jackedmech
Updated programmer with both Rev9 and Rev13 and still no joy on ABS issue and tire change.
Posted: Tue Dec 18, 2012 1:21 pm
so, same error on 9r13?
Posted: Wed Dec 19, 2012 10:55 am
by jackedmech
Yep, won't read the codes, clear the codes or change tire size to clear code. Not to happy.
Posted: Wed Dec 19, 2012 12:50 pm
this is odd, I have not had any complaints of this issue in years, will take some digging to sort it out.
Posted: Fri Dec 21, 2012 6:48 am
by jackedmech
Anything you can do would be great!!
