i put new tires on my truck for winter and the are a bit smaller. i went from a 275/60-20 to 265/70-17. i drove it around a couple times after the tires where put on. i came home and plugged in my u7137 and changed the tire size. took the truck for a ride and my first turn i made i noticed the blinkers where blinking much slower than usual. it continued the trip home.
once home i tried restarting the truck, no luck. undid the quick adjust, no luck. uninstalled the whole tune and went back to factory, still didnt fix it. i put the mpg tune back on and changed the tire size again. still not working correctly. this is rather annoying specially since i cant undo it. i would have rather my speedo been off than my blinkers be screwed up. this does happen with both blinkers and they do all blink just really slow. any advice would be appreciated. thanks!
Slow blinker after changing tire size?
Re: Slow blinker after changing tire size?
try factory tune again & after that disconnect the battery & wait 5min, go for a drive & see if fixed.
okay, ill give that a try in the morning. thanks!
oddly enough, i went out this morning and it was working normally... weird
my ram was doing the same thing even BEFORE i installed my tunes, my lamp out light would light up. Did some digging around on the net on some ram forums and found out it the most common cause for a lamp out light was the loose factory wiring harness up front with the turn signals light. But eventually my bulbs did go
then sensor was finding voltage drops to one bulb causing mine to light up
2013 Ram 1500 Express 5.7, Zone 6" lift, Predator 2 tuned,
