2007 Silverado 5.3L
Dr.Beardface
2007 Silverado 5.3L
Post by Dr.Beardface »
I installed the tune onto a 2007 Silverado with the 5.3L engine. Everything works fine up until about 35/40 mph when the ABS warning lights start flashing on the dash. The truck has slightly larger than stock tires (305/50R20) but this never happened before the tune. I tried inputting tire size directly, inputting tire diameter, changing the axle ratio, and also leaving it all at default settings but no matter what I did the ABS lights still came on. The inTune is fully updated as well.
Thanks.
TCM_24240464_LastTuneWritten.grg
(12.67 KiB) Downloaded 125 times
ECM_12616011_LastTuneWritten.grg
(50.89 KiB) Downloaded 120 times
info.xml
(613 Bytes) Downloaded 111 times
Dr.Beardface
Re: 2007 Silverado 5.3L
Any idea when you might be able to fix this issue? I'm not really comfortable driving the truck with the ABS freaking out...
