900 RPM max and no gauge activity 08' f350 6.4L
Post questions/comments about your Trinity for your Ford diesel truck.
Hillbilly1
Post by Hillbilly1 »
After current update my gauges will not move and the truck will only rev up to 900 or 950 rpm max. no monitoring, no trouble codes, no power. Worked great before new update. Help !!!!!!!!
:drivingbad: :drivingbad:
2008 F 350 SUPER DUTY
DSDownloader 2.2.2.6
Driver 1.1.1.1
Serial # 6K1O7E6-1
TRINITY
v.1r09b
PART# 8U7AME*
SAVED CALID PCM 8U7A-14C204-FE
TCM 8C3A-14C337-CA
Ford_can_diesel
VIN# 1FTWW33R98ED02826
Do not demand that which you cannot take by FORCE!!!
Hillbilly1
Re: 900 RPM max and no gauge activity 08' f350 6.4L
Is there any way i can get earlier version so i can use my Diablosport Trinity. I have no use for it since the v.1r09b updated crom. It was working with the v.1r09 version before the a and b updates.
Thanks you guys!!!!!!
:drivingbad: :drivingbad: :drivingbad:
sohfast94
Post by sohfast94 »
I've tested these with no issues. Ok well I'll have ot take a look again then I guess.
trinity_ford_can_diesel-1t09ak_update.crom
(3.87 MiB) Downloaded 1060 times
Insert Clever comment here...
sohfast94
Post by sohfast94 »
Actually before you do anything else which tune did you install? Did you try installing any others?
Hillbilly1
Yes, I tried towing, performance, and extreme with variations on transmission tunes also. All did the same thing. Should I go ahead and try new crom?
Hillbilly1
I have tried to load the new crom but it says its an older version and need password from DS tech.
Is there anyway to get a password for this soon.
:crashing: :crashing: :drivingbad:
Hillbilly1
I sent you a P.M. sohfast!!! Need new password for key. Thanks.
:crashing: :drivingbad: :crashing: :drivingbad:
sohfast94
Post by sohfast94 »
Better now?
Return to “Trinity Ford Diesel”
