2010 ram hemi idle issue
adventurer
Post by adventurer »
Hi all, am facing a problem when i raise the idle on my 2010 ram , normal on drive its 500 rpm so i tried to raise it to 700 rpm by adding 200 rpm using the predator with nothing happens it stays 500 on drive so i tried to raise 50 rpm to all : on N and Park with AC on and on D with AC on and also with AC off , it raised to 1200 rpm and wont go down , and when i raise only on D with AC off nothing happens it stayed 500 rpm no matter how many rpms i raise , any help how to raise it to at least 600 or 700 ??
( 1 ) 2010 RAM HEMI CC/ S&B CAI/87MM TB/JET 180 TSTAT/HKS TB GW/OIL BREATHER FILTER/Y PIPE/PYPES VIOLATOR MUFFLER/DS CUSTOM TUNE.
( 2 ) 06 Ram QC hemi 4x4 SLT, Sport , Magnaflow cat-back ,Y pipe , Poweraid TB spacer, HKS TB GW, SRT8 Mopar CAI, DS Custom tune, Oil breather filter, Jet 180 Tstat.
adventurer
Re: 2010 ram hemi idle issue
till now 6 days passed on post and no one can help !!
so, you can raise it to 1200, but not 700, am I reading that correctly?
adventurer
mikel wrote:so, you can raise it to 1200, but not 700, am I reading that correctly?
if i add 50 rpm to each N and P when ac on and to D when ac on and the same when ac off it raises to 1200 rpm in all conditions and if i only add to when on D with ac off alone nothing happens
please make the changes you mentioned, load the tune to the truck, then grab a copy of the last tune written from the Predator using DSDL and post it here.
What revision is the tool on?
adventurer
am using on tool 9r13
