2012 RAM 5.7, Any improvements to the first canned tune?
minnichsxr400
I been running the tunes that Diablosport put out for the 2012 ram 5.7. I been peaking 7 stknock on just bout any tune. i have exhaust, intake, and oil catch can. im not sure what stock was doing but id hope that these tunes are not hurting my engine. only other thing about the tunes i dont like is the amount of time it takes to shift going from 1st to 2nd and the fact that when i try to manual shift it full throttle it still shifts at its normal shift point. appreciate some responces on what people are doing to the tune to reduce knock and when and if diablosport is making a better tune now that they had the public test it out and recieved feedback on it.
Re: 2012 RAM 5.7, Any improvements to the first canned tune?
How much resonance does your CAI and/or exhaust have? The knock sensors are extremely sensitive in these trucks. Have you tried to reduce timing and datalog again to see if the knock goes away? If you have and it's doesn't change, then more than likely your knock sensors are picking up 'false' knock.
2012 Ram 1500
Do yourself a favor and get an updated tune from Sean at hemifevertuning.com. It is night and day between the Canned Diablo tune and the hemi fever tune. He also has a transmission reprogram that is part of the tune. You get quick sharp shifts now. It's only 125 dollars and is emailed for you to download it into your trinity on intune.
