WOT 74%
burnrubber
WOT 74%
Post by burnrubber »
Is it normal for data viewer to show 74% throttle at WOT ? 2012 V6 Mustang .Thanks in advance
2012 V6 Mustang 3:73 gear auto trans , Intune. 1986 Regal T Type, Turbo Tweak chip,scanmaster,Razor Alky.
Re: WOT 74%
got a log you can post?
burnrubber
Re: WOT 74%
New to this have logs dont know how to post them.
5liter Monsta
Re: WOT 74%
Post by 5liter Monsta »
Normal. Relative throttle position for my GT show the same. My camaro did the same.
----2013 Mustang GT MT82 DIBM 401a Premium Pack----
157dB
Re: WOT 74%
Post by 157dB »
Try re-calibrating your throttle pedal.
Turn key to run position.
Do not start engine.
Fully depress and release the throttle pedal SLOWLY
3 times within 5 seconds.
Turn key off.
Pedal calibrated.
This did wonders for my 07 Mustang. :)
5liter Monsta
Re: WOT 74%
157dB wrote:Try re-calibrating your throttle pedal.
Turn key off.
Pedal calibrated.
but this doesnt change the fact that the rel throttle position will still read below 100% correct?
burnrubber
Re: WOT 74%
I will give it a try thanks.
sohfast94
Re: WOT 74%
Post by sohfast94 »
Turn key off.
Pedal calibrated.
05-10 Fords only read up to 82% The 11-ups 90%
As far as the 74% do you have a log of it doing this?
The cars we've had in here didn't exhibit this although if it were to be doing it I'm sure I could fix it easily.
Insert Clever comment here...
burnrubber
Re: WOT 74%
It is 74.90% the question is, is the throttle only opening 74.90% or is the logging software just off abit.
Re: WOT 74%
software is reporting whatever the PCM tells it ;)
